Home > Maintenance & Modifications > Tip - Greasing the prop shafts |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1428 |
Don't forget to chock the wheels either when jacking it up with the transfer box in neutral.
The handbrake will not be operational, nothing to stop it moving or running away. |
27th Apr 2022 7:07pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17446 |
If you want to do a more thorough job, unbolt the flange at one end (at least, both ends is better) of the propshaft so that you can articulate the joint fully while greasing. It only takes a few minutes and significantly improves grease migration through the joint as well as allowing you to assess the condition of the needle-rollers. It also avoids any problems getting the connector onto the nipple between the yokes if you are using the original-style propshafts.
27th Apr 2022 7:25pm |
steveww Member Since: 05 Jan 2022 Location: Uppingham Posts: 570 |
Good point, well made. Fortunately my workshop floor is dead flat. |
27th Apr 2022 9:08pm |
