Home > Maintenance & Modifications > Defender 90 300Tdi Sill replacement |
Cubflyer Member Since: 25 Sep 2021 Location: Suffolk Posts: 278 |
Hi folk ...
Hope this is a "Simple" question: What time (hours of work / worst case) would you estimate it would take to fit new sills (both sides) please? Looking underneath, they don't look too bad but the screws/nuts look corroded. Many thanks John 2010 Defender 90 300Tdi CW (White/1994) 2021 Defender 90 300Tdi SW (Blue/1994) |
24th Apr 2022 6:44pm |
Thanks for that info ... and "If" you were doing it ... how long for both sides?? 2010 Defender 90 300Tdi CW (White/1994)
24th Apr 2022 7:58pm |
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 808 |
Just a thought, are we talking about the aluminium dresser panels or the steel u-channel that holds it all together?
If the latter the same still applies but there is a bracket at the front that bolts to the bulkhead with an insert that has 2 captive bolts on a plate. The plate will be corroded wafer thin and twist/snap so you either need to make or buy a new one. Either way 1-1.5 hrs per side maybe? These jobs take as long as they take and you usually find something to tinker with as you go. |
24th Apr 2022 8:13pm |
From memory I think the steel channel brackets front and rear are M8 nuts/bolts.
24th Apr 2022 8:16pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3410 |
On later Defenders, the rear U channel bolts (talking about the bolts that attach to the tub on a 90) are M6 into a captive square nut that spins with the minimal effort. I do not know when the change to M6 was done, possibly when the seat belt lower mount was eliminated and moved to the same bracket as the retractor? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
25th Apr 2022 5:56am |
