Home > Maintenance & Modifications > Defender 90 300Tdi Sill replacement
Cubflyer
United Kingdom 1994 Defender 90 300 Tdi SW Arles Blue
Hi folk ...
Hope this is a "Simple" question:
What time (hours of work / worst case) would you estimate it would take to fit new sills (both sides) please?
Looking underneath, they don't look too bad but the screws/nuts look corroded.
Many thanks
John 2010 Defender 90 300Tdi CW (White/1994)
2021 Defender 90 300Tdi SW (Blue/1994)
Post #950368 24th Apr 2022 6:44pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
All the bolts will snap, but this is good because it saves you trying to wind the nut off over the rusted threads.
Buy yourself a bag of M6 x 20 bolts, nylock nuts, washers and oversize washers ready for refitting the sills. Plenty of grease on the bolts incase you need to take them out again in the future.
Post #950381 24th Apr 2022 7:56pm
Cubflyer
Thanks for that info ... and "If" you were doing it ... how long for both sides?? 2010 Defender 90 300Tdi CW (White/1994)
Post #950383 24th Apr 2022 7:58pm
I Like Old Skool
Just a thought, are we talking about the aluminium dresser panels or the steel u-channel that holds it all together?
If the latter the same still applies but there is a bracket at the front that bolts to the bulkhead with an insert that has 2 captive bolts on a plate. The plate will be corroded wafer thin and twist/snap so you either need to make or buy a new one.
Either way 1-1.5 hrs per side maybe? These jobs take as long as they take and you usually find something to tinker with as you go.
Post #950388 24th Apr 2022 8:13pm
I Like Old Skool
From memory I think the steel channel brackets front and rear are M8 nuts/bolts.
Post #950389 24th Apr 2022 8:16pm
Dinnu
On later Defenders, the rear U channel bolts (talking about the bolts that attach to the tub on a 90) are M6 into a captive square nut that spins with the minimal effort. I do not know when the change to M6 was done, possibly when the seat belt lower mount was eliminated and moved to the same bracket as the retractor? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #950404 25th Apr 2022 5:56am
