![]() | Home > Puma (Tdci) > Tik tlk tik |
Race.it Member Since: 27 Aug 2019 Location: Algeciras Posts: 828 ![]() ![]() ![]() |
T shirt in diff that’s a new one.
You sure previous owner is not in the wheel well abs banging two spanners together every now and again? Searching for my first Defender...and started just as Covid hit, so talk about timing. 5 months after starting the search I found it, and here is the details |
110 Iain Member Since: 11 Nov 2019 Location: Scotland Posts: 82 ![]() ![]() ![]() |
Can't believe it I've done 20,0000 miles with that in there kinda proud of her that oily rags been all over the country Endeavour To Persevere
JPE Member Since: 19 Nov 2018 Location: South West England Posts: 337 ![]() ![]() ![]() |
Maybe previous owner got fed up with the clicking & shoved a t shirt in the diff to “fix” it ?
Offending rag in diff Endeavour To Persevere
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3479 ![]() ![]() ![]() |
So the tik tik tik noise is gone?
Once heard a guy saying that he stuffs ladies tights into noisy Escort Mk1s diffs to quite things up!!! He said it melts and thickens the oil!! ![]() 2012 90 CSW, 2.2TDCI, Santorini Black |
Hi Did 4 miles Sunday ticking proper loud people on street notice drove same 4 miles to work today no noise that's first time in 2 weeks will probably make noise on way home was very cold this morning only difference I can think of I had filled that diff 3 times and never spotted rag in there it still sounds like large stone in tire no sound if car on stands it driving me nuts Endeavour To Persevere
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20612 ![]() ![]() |
Have you tried running without the suspect diff in 2wd? Chillin In The Backwoods🇬🇧🇺🇸
Update decided to to fit new hub and new bearings plus changed bearing on stub axle old hub had snapped drive flange bolt and when fitting new one managed to snap one brand new bolt old ones fine oh the joy but hey done about 20 miles today and no clicking noise diff seems fine without any clothing on just need to put new disc on other side now hopefully I don't snap anything on this side thanks to all for your support Endeavour To Persevere
