Home > Td5 > Slickshift |
balmybaldwin Member Since: 17 Apr 2021 Location: Surrey Posts: 192 |
Can someone educate me on what different the turret makes over and above the slickshift kit? e.g. this bundle https://www.onlinegearboxparts.com/product...d5-bundle/
over this one: https://defenderupgrades.co.uk/product/lan...t-inc-td5/ |
11th Apr 2022 8:32pm |
katana069 Member Since: 28 Mar 2022 Location: Northern Ireland Posts: 44 |
I had a Slickshift installed last week and the difference is remarkable. Didn't upgrade the turret as mine was in goog nik with only 120k on the clock
11th Apr 2022 8:53pm |
I was going to say might do mine as well as I'm at 125K ... but no idea if mine is worn what are the symptoms?
11th Apr 2022 9:19pm |
You could take your original out and have a wee look before you order it only a 45min job.. just a thought..
12th Apr 2022 7:38am |
Joel Member Since: 18 Oct 2020 Location: Rotherham Posts: 76 |
I have just had mine fitted with the new gearbox, and it’s night and day. No more stirring the spanners to change gear.
I would highly recommend. |
21st Apr 2022 4:58pm |
Tufty Member Since: 27 Nov 2020 Location: Near Guildford Posts: 19 |
I fitted a slickshift and it made quite a difference to mine at 125k. I should have probably have changed the turret too as mine was borderline, but overall a great improvement - and a heck of a lot easier to fit than the LOF powerspring!
21st Apr 2022 5:26pm |
andyg0141 Member Since: 25 Feb 2022 Location: Glasgow Posts: 28 |
I’ve just done the shifter and spring (didn’t do turret as it looked ok even at 140k) and the difference is incredible - well worth it (despite the spring being rather fun to fit!)
5th Jun 2022 3:07pm |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2852 |
Well, l've just received the Slick Shift kit for my 140,000 mile TD5 110 so looking forward to seeing what difference it makes.
5th Jun 2022 9:46pm |
Did you get a replacement turret as well or retaining the original?
5th Jun 2022 9:47pm |
