Home > Puma (Tdci) > Warn Winch M800 in original D 90 winch bumper? |
MaxD90 Member Since: 26 Sep 2011 Location: Dominican Republic Posts: 12 |
Hi
This can be a silly rookie question but here I go: This winch: http://www.winchdepot.com/Winches-Winch-Ac...n=WAR26502 Can be installed in the original land rover defender winch bumper? I want to be sure before I put the order, I mean, does it fit? I dont wave to do any adaptation? Anyone have experience with this Warn winch? Thanks! One life, live it. |
18th Oct 2011 11:44pm |
Thanks Zagato for your time and info.
I just order the M8000 Warn winch for my D90. I upload 2 pics of the original winch bumper. Check out the album. Do you have stock front shock absorbers? Why you take your winch off? Is it that bad? PS: Very neat 110 you have. Thanks!!!! One life, live it. |
19th Oct 2011 6:25pm |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5012 |
In a dash for the school run but from memory it all weighs 65KG but the Devon 4x4 bumper is a solid bit of kit, if the LR bumper is like the standard one it will be rusting in the post to you but maybe a lot lighter and maybe perfectly OK of course - quite a few owners on here have them so will hopefully comment. The fair-lead rollers also weigh a ton on their own as well as the steel cable so you could take a good chunk out of the weight by replacing those. The standard springs were fine, it didn't dip at the front, improved the ride but not the handling..............which I am now about to test to get kids to school on time
Edit - looked at your bumper in the gallery looks fine but is it the deeper one for air-con which I think you have! |
20th Oct 2011 7:23am |
