![]() | Home > Maintenance & Modifications > 21.6 PROBLEMS DETECTED WITH DRIVER DEMAND |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5873 ![]() ![]() |
I would have thought that a 2000 year Td5 would only be a two track pedal, and not the later 3 track one.
vitsdef Member Since: 08 Apr 2022 Location: Tuscany Posts: 3 ![]() ![]() ![]() |
Hi, yes, i made a mistake:
"...the setting of the potentiometer on the nanocom from 3 to 2 tracks..." -> should be "...the setting of the potentiometer on the nanocom from 2 to 3 tracks...". This weekend the error came up twice again. Maybe i should re-do the wiring from the pedal to the ECU? I was looking at the electrical diagrams of the TD5 and need a clarification: what is header 0291 (K109), it doesnt appear in the connector library, and where is it? ![]() ![]() |
I’ve redone the wiring from ecu to pedal 3 or 4 times now using trailer cable (as it has enough strands inside) and it not that difficult to do.
Thanks, i've redone the wiring and it seems it has cured the problem!!
