Home > Maintenance & Modifications > Problems fitting new intercooler
balmybaldwin
United Kingdom 2002 Defender 90 Td5 CSW Buckingham Blue
Hello, after a week or so of looking at it, I took the plunge to change my intercooler this weekend.
It has proved somewhat problematic which is a surprise given how many people say it just drops in
Basically eveything came out ok, I then removed the plastic lugs on the radiator as per the alive fitting instructions.
After an hour wrestling with hoses I got the new intercooler in. However I'm not happy with how it fits.
It took substantial jiggling of the bonnet catch, and the "A" bar supports in to order that they don't touch the new intercooler. (0.5-1mm gap!) this is probably now "OK"
Despite removal and reassembly several times there is something on the nearsside wrong...The bracket on the nearside of the intercooler was fouling the intercooler slightly so I removed a bit of it with an angle grinder to allow clearance, but while it will now fit on the bracket, the intercooler sticks out too far forwards for me to tighten the support (a)bars and I've had to shim it at the top to make it possible to even get the bar on as it was specifically the bottom corner that was sticking out too much.
For now I've got a bit of cardboard to stop rubbing, and the plan is to take it to local specialist with tail between my legs on Tuesday.
Despite this it all works and is an improvement on my old deformed one, but I'm wondering if what ever deformed the intercooler (before I bought it) bent the bracket some how but nothing else seems out of whack
It is also possible I've screwed up somewhere as getting the fan cover on was much harder than getting it off.
Overall I would say the intercooler is 5mm too far forward on the nearside only. I can't see that anything is backwards or that I've used the wrong holes etc.
Any ideas?
This is the offending bracket that seems to be causing the issues:
My temp solution to get me to garage:
I'm sure the plastic cover didn't have a gap to the slam bar before:
Old intercooler
Post #949658 17th Apr 2022 4:42pm
Screbble
I can’t help personally as I have yet to replace mine, but I agree that something isn’t quite right -especially as others report it’s a quick and easy ‘swap.’
Let’s hope someone pops along shortly with the inevitable sound advice we come to expect on this forum 👍
Good luck.
Post #949723 18th Apr 2022 9:18am
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
I had similar issue with fitting a Serck intercooler on my tdci a couple of years ago.
I had to shim the a-bar supports with washers at the bottom mount to clear intercooler and have similar gap with the cowling.
I had no problem with the bonnet catch.
One of the upper pins sheared but has been fine since replacing with a nut/bolt.
Post #949729 18th Apr 2022 11:26am
balmybaldwin
Thanks, i seems such a nice fit on the drivers side, but just can't figure out what I've done wrong as everything else (including bonnet) fits.
I can see some scope for "adjusting" the bracket with a hammer/vice, but don't want to go down this route without confirmation from a pro, so will pootle over to garage at lunch time tomorrow
Post #949735 18th Apr 2022 12:51pm
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
I have recently fitted my BAS one and its huge. It comes with shims for he bottom of the a bars, and even then i had to add a couple more washers. The top of the a supports were still touching and i had to have one person pulling the bars and the top panel forward while i tightened it. It took me ages to get it right.
Post #949852 19th Apr 2022 2:42pm
balmybaldwin
That sounds like what I did yesterday. I'm now much happier with clearance all around but fundamentally I have shimmed out one side, but not the other which seems wrong. Having said that it's all working, and def feels like it pulls better than the old deformed intercooler.
I would be curious to know what your BAS measures from front pin to front pin as it def feels like one of my brackets sticks out too much from the wing and some adjustment would help centre the pin on the intercoller with the hole
Post #949854 19th Apr 2022 3:03pm
balmybaldwin
So the verdict from my local specialist is:
"Oh, that's quite common. Looks ok as it, if I want to then "adjustment" of the bracket is probably the way to go"
So I'm happy to leave as it and add bracket adjustment to my "when I get the time" jobs list Thumbs Up
Post #950002 21st Apr 2022 3:42pm
