Home > Maintenance & Modifications > head lamp adjustment
kljw
Scotland 2009 Defender 90 Puma 2.4 SVX Soft Top Auto Santorini Black
hi all
need to adjust the level of one of the headlamps, can anyone tell me what i should be looking for as an adjuster please. there is no self leveling on my puma. Cheers
keith
puer claudius
Post #9383 3rd Apr 2009 12:20pm
Grockle
Keith, there are 2 adjusting screws for each located on the rim.why do you need to adjust them ? 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #9385 3rd Apr 2009 12:34pm
kljw
Grockle
the right side is higher than the left, and is quite noticable. i have just had a HID light conversion done, so maybe they have just been knock out of alignment. not big problem, just need to know what i am looking for, hate to turn the wrong thing so to speak.
Also, do you acees the adjuster from inside the engine compartment or exteranaly? Cheers
keith
puer claudius
Post #9386 3rd Apr 2009 12:43pm
Grockle
I'm sure if look at the head light the 2 screws are visible bottom one for vertical the other for horizontal adjustment.line it up to the correct light in front of a wall etc. 2.4 90 XS
Post #9387 3rd Apr 2009 1:40pm
kljw
Grockle,
thanks for that, they are now in line, and are very bright! Cheers
keith
puer claudius
Post #9494 7th Apr 2009 11:13am
Grockle
Good,glad to have been of help, Keith you prob know that they are illigal without auto dip and washers. 2.4 90 XS
Post #9496 7th Apr 2009 12:07pm
kljw
hi,
yes i was, but have adjusted the lights low, so as not to cause problems to other uses. also, looking into some form of washer setup for the main lights. not a legal solution, but steps in the correct direction. Cheers
keith
puer claudius
Post #9501 7th Apr 2009 12:59pm
Grockle
Pete as BAS was looking into them. 2.4 90 XS
Post #9502 7th Apr 2009 1:18pm
kljw
i know, have rwead his post and seen the pictures he posted, hence why i had mine converted. Cheers
keith
puer claudius
Post #9551 8th Apr 2009 5:00pm
