Home > Maintenance & Modifications > head lamp adjustment |
kljw Member Since: 23 Jan 2009 Location: Edinburgh Posts: 265 |
hi all
need to adjust the level of one of the headlamps, can anyone tell me what i should be looking for as an adjuster please. there is no self leveling on my puma. Cheers keith puer claudius |
3rd Apr 2009 12:20pm |
Grockle
the right side is higher than the left, and is quite noticable. i have just had a HID light conversion done, so maybe they have just been knock out of alignment. not big problem, just need to know what i am looking for, hate to turn the wrong thing so to speak. Also, do you acees the adjuster from inside the engine compartment or exteranaly? Cheers keith puer claudius |
3rd Apr 2009 12:43pm |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
I'm sure if look at the head light the 2 screws are visible bottom one for vertical the other for horizontal adjustment.line it up to the correct light in front of a wall etc. 2.4 90 XS
3rd Apr 2009 1:40pm |
Grockle,
thanks for that, they are now in line, and are very bright! Cheers keith puer claudius |
7th Apr 2009 11:13am |
Good,glad to have been of help, Keith you prob know that they are illigal without auto dip and washers. 2.4 90 XS
7th Apr 2009 12:07pm |
hi,
yes i was, but have adjusted the lights low, so as not to cause problems to other uses. also, looking into some form of washer setup for the main lights. not a legal solution, but steps in the correct direction. Cheers keith puer claudius |
7th Apr 2009 12:59pm |
Pete as BAS was looking into them. 2.4 90 XS
7th Apr 2009 1:18pm |
i know, have rwead his post and seen the pictures he posted, hence why i had mine converted. Cheers
8th Apr 2009 5:00pm |
