Home > Maintenance & Modifications > Puma hand held fault code-reset reader.
HAWKEYE
Looking to buy an inexpensive fault code reader. I'm sure I've seen a best type mentioned here.
Found several new on ebay ranging from 20 to £60.00.
Post #949248 13th Apr 2022 9:41am
OBD2 one I had for Ford codes worked on mine, it was a blue one and cheap. It allowed fault code read, and clearance.
At least for an early Puma it worked perfectly with mine.
Now I use Alive’s ATRIC. No Guts, No Glory.
Post #949284 13th Apr 2022 5:07pm
HAWKEYE
fault reader
Thanks for the info'. Purchased one for £40.00. See how it goes.
Post #949291 13th Apr 2022 6:24pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
HAWKEYE, you're not using Bearmach's HawkEye Question Very Happy
Post #949358 14th Apr 2022 1:52pm
camelman
I used an OBD reader that cost £8 on ebay and the 'Torque' app which is £3
Post #949366 14th Apr 2022 3:05pm
