Home > Maintenance & Modifications > Puma hand held fault code-reset reader. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20506 |
OBD2 one I had for Ford codes worked on mine, it was a blue one and cheap. It allowed fault code read, and clearance.
At least for an early Puma it worked perfectly with mine. Now I use Alive’s ATRIC. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
13th Apr 2022 5:07pm |
HAWKEYE Member Since: 20 Mar 2022 Location: kent Posts: 5 |
Thanks for the info'. Purchased one for £40.00. See how it goes.
Cheers |
13th Apr 2022 6:24pm |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1082 |
HAWKEYE, you're not using Bearmach's HawkEye
14th Apr 2022 1:52pm |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3383 |
I used an OBD reader that cost £8 on ebay and the 'Torque' app which is £3
14th Apr 2022 3:05pm |
