Home > Maintenance & Modifications > Help....Installing Plywood panneling
babbolla
1985 Defender 110 300 Tdi USW Baltic Blue
Hi all,
I want to fit marine ply to the inside rear of my 110. What is the best method for doing it? I have heard you should use self tapping screws but presume you need small pilot hole in the steel sides!!!
Does anyone have any good suggestions for fitting insulation behind the ply? Can you buy self adhesive insulation?
Chhers for any help offered.
Babbs
Post #94869 18th Oct 2011 2:05pm
jst
floor, seat boxes or sides? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #94874 18th Oct 2011 2:19pm
babbolla
I had only thought of doing the sides as my wheel boxes are full of holes from the previous owner having fixed a box to it! Was thinking of using marine ply 10mm but not sure abour water getting between the ply and the aluminum arch...should I worry?
Floor is going to have thick rubber matting to stop dogs from siding about!
Post #94880 18th Oct 2011 2:34pm
Killer90
Site Sponsor
we use self tappers at work and you can buy self adhesive sound proofing/insulation from ebay etc Very Happy
Post #94895 18th Oct 2011 4:55pm
wurzell
hi babbolla Very Happy we used dynamat soundproofing and is a very good insulater good quality stuff weve used it for years in sound off comp cars highly recomended Thumbs Up paul n tash
Post #94905 18th Oct 2011 5:27pm
babbolla
The self tappers...can they go straight into the body or should they have pilot holes?
Post #94933 18th Oct 2011 7:30pm
landy andy
I'd do pilot holes, unless using pias (self drilling) screws
Andy
Post #94947 18th Oct 2011 8:09pm
Killer90
Site Sponsor
yer u will need to drill pilot holes dont go to big though Laughing
Post #94957 18th Oct 2011 8:48pm
Happyoldgit
You need pilot holes into which the self tappers screw, they can't drill into the metal themselves ...and obviously you won't be fitting screws into the exterior body panels but rather into the hardtop and body tub frame. TGE do some ply panels - at a price.
http://www.tge-defendertrims.co.uk/index.htm Steve.
http://forums.lr4x4.com
Post #94958 18th Oct 2011 8:48pm
babbolla
Thank you for all the advice so far, one further question:
1) If i wanted to put ply over the wheel boxing, how to I attach the ply?
a) attach them the same as the side pannels i.e. with self tapping screws! But can this be done to the aluminium arches?
b) Create a frame (either timber or metal) around the wheel boxes to attach th eply to. But this would obviously reduce the interior space.
Babbs
Post #95023 19th Oct 2011 10:15am
If I was going to clad the seat boxes with ply then I'd drill right through and bolt them in place rather than use self-tappers. Use countersunk bolts and a blob of silicon or similar underneath to prevent moisture getting between the ply and the ali. Darren
Post #95025 19th Oct 2011 10:23am
babbolla
Cheers Darren.
Thats what I thought but prefer to ask around before committing to it.
Babbs
Post #95026 19th Oct 2011 10:31am
Happyoldgit
You could glue the ply to the boxes with blobs of Sikaflex or similar but you'd have a devils own job if you ever wanted to remove it. For inspiration seek out interior photos of ex utility, service or commercial Defenders. Steve.
Post #95031 19th Oct 2011 10:58am
Killer90
Site Sponsor
self tap again or nut and bolt it we use the a bolt with no head you drill the hole bash the bolt through and underneath the arch you can get to the bolts do up with nut Smile
Post #95080 19th Oct 2011 4:29pm
babbolla
Thanks for all the responses Thumbs Up
Post #95358 21st Oct 2011 8:57am
