![]() | Home > Maintenance & Modifications > Nuget Stuff Sealed Airbox and RAI Install Notes |
swt Member Since: 24 Aug 2018 Location: Cumbria Posts: 167 ![]() ![]() ![]() |
Great notes. I fitted a nugget stuff airbox last year and had a similar experience getting the standard box out and the new one to sit correctly. A bit of fettling round the fittings was needed to get everything into a useable position. My fresh air intake still ended up very close to the engine/turbo and so rather than use the supplied hard plastic piece, I piped up using my own fittings, to the Naka wingtop intake that I already had. It's all a very satisfactory, if rather expensive, solution.
There's a useful post elsewhere on here identifying the replacement filter from other manufacturers, at a sensible price. |
Not_Given Member Since: 25 Dec 2017 Location: UK Posts: 94 ![]() ![]() ![]() |
Dear Big110,
Thank you ver much for the write-up. I have an SD Snorkel and Nuggetstuff intake waiting for me when I get home. Have already decided the stock intake is getting sawn in half with out even looking under the bonnet! NG |
big110 Member Since: 02 Nov 2016 Location: Sweeden Posts: 342 ![]() ![]() |
Feel free to reach out if I can help in any way. I’m also on WhatsApp
Also YESSSSS on the stock air box. Get out the sawzall! Hah |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2275 ![]() ![]() |
This is a reasonable guide, for RHD Puma’s https://www.firstfour.co.uk/wp-content/upl...er-box.pdf
