![]() | Home > For Sale & Wanted > [For Sale] Defender Snow Plough |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3396 ![]() ![]() |
The Ultimate Defender Accessory!!
This is a snow plough from UK Snow ploughs www.uksnowploughs.co.uk It isn't one made from tin like those typically found on ebay and is constructed from 4mm plate. There is a custom a-bar that fits any Non AC Defender and has 2 tow balls to attach the plough. A heavy duty ratchet strap can then be used to raise and lower the plough. It's simple to fit / remove and doesn't leave you with half a ton of hydraulics mounted to the front of your truck when not in use ![]() Has height adjustable wheels to set the height and a heavy duty replaceable rubber strip. Has 5 positions from straight ahead to out at an angle. It's in excellent condition having never been used in anger, and comes with the custom artwork!! For a couple of hundred quid, the manufacture can also supply the winch operating version of the mount. They retail for £1980. Asking £925. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Last edited by camelman on 11th Apr 2022 11:13am. Edited 2 times in total |
mini Anaconda Member Since: 23 Aug 2016 Location: Thames Valley Posts: 811 ![]() ![]() |
That looks great
![]() Sadly I have absolutely no justification for it. ![]() ![]() |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2231 ![]() ![]() ![]() |
How heavy is it please?? And rough dimensions..
1.97m wide, 0.6m high.
I'd put the weight at about 70kg but not sure. ![]() |
Smyles_ Member Since: 26 Aug 2018 Location: Copenhagen Posts: 519 ![]() ![]() |
Would it be easy to modify for A/C'd Defenders or is it out of the equation, and are the tow balls mounted to the removable A-bar (don't like the look of tow balls on front bumpers)? Stuart
![]() Cummins 130 Build Thread 58 130 Double Cab HCPU - Cairns Blue 04 110 Double Cab - Black (gone) 07 Audi RS4 Avant - Silver |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1886 ![]() ![]() |
That's awesome, can you post
![]() GLWTS, bargain for someone ![]() 1993 200tdi 90 hard-top 1998 300tdi 90 soft-top |
The tow balls are mounted to the A frame not the bumper. I think it would be easy enough to modify an AC A bar to add the plates to mount the tow balls.
Rescue01 Member Since: 17 Jul 2015 Location: Aberdeen Posts: 105 ![]() ![]() |
Why do I want this I’ve no need
Cheers Mr Camel. I will sit quietly in the back but if there are no takers I'll PM you later down the line. Stuart
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2303 ![]() ![]() ![]() |
Good Luck with the Sale camelman
Certainly good valve when compared with buying a 'fixed' set-up... (currently for sale at 33K) ![]() Click image to enlarge Oh to have the only Snow Plough in the Village... adds a whole other level to being a 4x4 Responder ![]() https://www.defender2.net/forum/topic83242.html |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17724 ![]() ![]() ![]() |
I have absolutely no need for this but, my goodness, I want it!
Irrational or what? |
You're not the only one!
Bump and price drop....
