Home > For Sale & Wanted > [For Sale] Defender Snow Plough
camelman
The Ultimate Defender Accessory!!
This is a snow plough from UK Snow ploughs www.uksnowploughs.co.uk
It isn't one made from tin like those typically found on ebay and is constructed from 4mm plate.
There is a custom a-bar that fits any Non AC Defender and has 2 tow balls to attach the plough.
A heavy duty ratchet strap can then be used to raise and lower the plough.
It's simple to fit / remove and doesn't leave you with half a ton of hydraulics mounted to the front of your truck when not in use Whistle
Has height adjustable wheels to set the height and a heavy duty replaceable rubber strip.
Has 5 positions from straight ahead to out at an angle.
It's in excellent condition having never been used in anger, and comes with the custom artwork!!
For a couple of hundred quid, the manufacture can also supply the winch operating version of the mount.
They retail for £1980.
Asking £925.
Post #948137 5th Apr 2022 9:14am
mini Anaconda
That looks great Bow down
Sadly I have absolutely no justification for it. Big Cry BORG - Bucks & Oxon 4x4 Response Group
Post #948220 5th Apr 2022 8:31pm
discomog
Even though I sleep with my financial director, I don't think she would approve this - having already approved a ballast roller and a set of chain harrows this year for me to play with. Looks a bargain so good luck with the sale. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #948226 5th Apr 2022 9:00pm
90 Dreamer
How heavy is it please?? And rough dimensions..
Post #948235 5th Apr 2022 9:10pm
camelman
1.97m wide, 0.6m high.
I'd put the weight at about 70kg but not sure.
Post #948241 5th Apr 2022 9:23pm
Smyles_
Denmark
Would it be easy to modify for A/C'd Defenders or is it out of the equation, and are the tow balls mounted to the removable A-bar (don't like the look of tow balls on front bumpers)? Stuart
Cummins 130 Build Thread
Instagram
58 130 Double Cab HCPU - Cairns Blue
04 110 Double Cab - Black (gone)
07 Audi RS4 Avant - Silver
Post #948354 6th Apr 2022 5:23pm
CarMan
That's awesome, can you post Rolling with laughter
GLWTS, bargain for someone Thumbs Up Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
Post #948370 6th Apr 2022 6:26pm
camelman
The tow balls are mounted to the A frame not the bumper. I think it would be easy enough to modify an AC A bar to add the plates to mount the tow balls.
Post #948398 6th Apr 2022 8:54pm
Rescue01
Why do I want this I’ve no need Laughing GLWTS It looks like a good bit of kit.
Post #948409 6th Apr 2022 11:09pm
Smyles_
Denmark
Cheers Mr Camel. I will sit quietly in the back but if there are no takers I'll PM you later down the line. Stuart
Instagram
Post #948447 7th Apr 2022 9:57am
X4SKP
Good Luck with the Sale camelman
Certainly good valve when compared with buying a 'fixed' set-up... (currently for sale at 33K)
Oh to have the only Snow Plough in the Village...
adds a whole other level to being a 4x4 Responder Thumbs Up SKIP
Post #948454 7th Apr 2022 10:43am
I have absolutely no need for this but, my goodness, I want it!
Irrational or what?
Post #948470 7th Apr 2022 1:16pm
Laurie
You're not the only one! Very Happy
Post #948476 7th Apr 2022 1:40pm
camelman
Bump and price drop....
Post #948987 11th Apr 2022 11:14am
