Home > Puma (Tdci) > Vacuum Pump Failure 2.4 Tdci |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8018 |
That's a great, useful post, thank you for taking time to post. Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
17th Nov 2018 5:02pm |
Snorkers Member Since: 10 Oct 2015 Location: Grampian Posts: 34 |
Regarding my submission above - the three bolts which hold on the vacuum pump are M8 x 75mm bolts. They are not M10. The socket for their removal is a 10mm socket. Preferably a deep socket, as the bolt nearest the wing has a portion is thread which extends above the bolts head. It's obvious if you see it in the flesh so to speak. Hope this hasn't caused any confusion.
Regards again. Snorkers. |
18th Nov 2018 1:17pm |
Badger110 Member Since: 06 Feb 2018 Location: South hams Posts: 1039 |
Thanks for the info
18th Nov 2018 1:54pm |
CarlUK Member Since: 04 May 2021 Location: Devon Posts: 3 |
Thank you this is very useful information.
4th Apr 2022 10:05pm |
