Home > Maintenance & Modifications > Part number needed
bob neville
Part number needed
Anybody got the part number for the plastic screw in expansion stud that holds the interior rear light covers in place on a 110 double cab ?
I have looked everywhere, including the linked parts list, and I can't find them.
Thanks
Bob
Post #94744 17th Oct 2011 6:17pm
MK
My MC shows lamp, bulb and bracket Question Puma 110" SW
Post #94754 17th Oct 2011 6:53pm
bob neville
Hi MK
In the double cab the rear lights are covered by a plastic cover in the tub. This is held in place by studs that have a plastic screw that expands the stud. Problem is that the screw head gives way before in can be removed.
Bob
Post #94757 17th Oct 2011 7:00pm
MK
I do not see it. I guess it is a special one, right? Puma 110" SW
Post #94758 17th Oct 2011 7:19pm
bob neville
Thanks MK - it must be double cab specific.
I will go to the stealers and get some ordered.
Bob
Post #94760 17th Oct 2011 7:31pm
mse
Im sure you can pick them up in halfords - if they are the ones im thinking they are a common part...like a plastic rivet but the centre is a screw? Mike
Post #94779 17th Oct 2011 9:11pm
Fifth Horseman
It may be EYQ100130 Rivet-Plastic
It's in section D06.005 Body Electrics, In-car-entertainment
IIRC the ones MSE refers to will just about fit, but are a slightly different size.
Post #94806 18th Oct 2011 7:17am
bob neville
Thanks Fifth Horseman - that is the one Thumbs Up
That must be about the only section of MC I didn't look in Embarassed
Bob
Post #94813 18th Oct 2011 8:13am
MK
The same used in rear seats plastic trim cover (SW) Smile Puma 110" SW
Post #94820 18th Oct 2011 8:38am
