Home > Maintenance & Modifications > Part number needed |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
Anybody got the part number for the plastic screw in expansion stud that holds the interior rear light covers in place on a 110 double cab ?
I have looked everywhere, including the linked parts list, and I can't find them. Thanks Bob |
17th Oct 2011 6:17pm |
Hi MK
In the double cab the rear lights are covered by a plastic cover in the tub. This is held in place by studs that have a plastic screw that expands the stud. Problem is that the screw head gives way before in can be removed. Bob |
17th Oct 2011 7:00pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2436 |
I do not see it. I guess it is a special one, right? Puma 110" SW
17th Oct 2011 7:19pm |
Thanks MK - it must be double cab specific.
I will go to the stealers and get some ordered. Bob |
17th Oct 2011 7:31pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5045 |
Im sure you can pick them up in halfords - if they are the ones im thinking they are a common part...like a plastic rivet but the centre is a screw? Mike
17th Oct 2011 9:11pm |
Fifth Horseman Member Since: 08 Mar 2011 Location: Lanarkshire Posts: 327 |
It may be EYQ100130 Rivet-Plastic
It's in section D06.005 Body Electrics, In-car-entertainment IIRC the ones MSE refers to will just about fit, but are a slightly different size. |
18th Oct 2011 7:17am |
Thanks Fifth Horseman - that is the one
That must be about the only section of MC I didn't look in Bob |
18th Oct 2011 8:13am |
The same used in rear seats plastic trim cover (SW) Puma 110" SW
18th Oct 2011 8:38am |
