![]() | Home > Td5 > Radio Bezel |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 964 ![]() ![]() ![]() |
Part number FHF000070PMA
Good luck 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
Enid_Puceflange Member Since: 25 Oct 2014 Location: edinburgh Posts: 1179 ![]() ![]() ![]() |
Mine did the very same
The radio has nothing supporting it at its rear when inserted and the weight of it bouncing up & down unsupported results in cracks then breaks in the bezel I reinforced mine in the reverse of it with two part epoxy, it lasted roughly a year When I re do it, I’m going to figure out a support for the back of the radio unit to hopefully give me more time Finding them new is a challenge, I gave up ![]() |
mattc Member Since: 10 Apr 2019 Location: Cheshire Posts: 73 ![]() ![]() ![]() |
I was told they stopped making them. I put mine on eBay when I converted mine to double din and it sold for a ridiculous amount.
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 ![]() ![]() ![]() |
The radio should have a rubber spigot screwed into the back of it which goes through the oval hole in the plastic cover behind the dash to support the rear of it.
Sadly most aftermarket radios no longer come with the screw in rubber bit. Steve 02' 110 TD5 Double Cab Rebuild Thread |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2657 ![]() ![]() ![]() |
Have you considered plastic welding it using a soldering iron, staples to sink into the join then a zip tie to fill in any gaps and holes.
It could then be sanded smooth and either re sprayed or even wrapped black. You tube can help you there. It’s something I have dabbled with and you do get better with practice. Good luck. ![]() |
