Home > Puma (Tdci) > Thudding sound under passenger side
The Anti Christ
Jamaica 2009 Defender 110 Puma 2.4 SW Santorini Black
My PUMA 110 has developed a persistent thudding sound under the passenger side footwell which occurs only when on unpaved road.
The thudding is not metal to metal, but sounds more muffled as if from a freely moving rubber suspension component.
A visual inspection of the radius arm bushings and rear mounts doesn't indicate anything unusual.
Also notice a considerable pulling to the left in the steering wheel...
Was wondering if anyone here had encountered similar symptoms? Just fix it before your friends find out it broke again - Landy Life Forever!
Post #947194 27th Mar 2022 3:46pm
matchap801
United Kingdom 2009 Defender 90 Puma 2.4 CSW Zermatt Silver
Jack up the front left wheel and give it a spin. Wheel bearing or disc/calliper issue? 2009 Defender 90 CSW 2.4 TDCI.
Ex Army Mechanic still living the dream.
Post #947201 27th Mar 2022 4:30pm
landy andy
Anti rollbar bushes?
You sure it not something in the battery box?
Post #947207 27th Mar 2022 6:06pm
Check upper and lower front damper rubbers, also bonnet hinge plastic bushes, failing that as suggested take a look at the ARB links and bushes.
In effect try and bounce the suspension you should be able to zero in on it if you do though I know itโ€™s easier said than done.
If you canโ€™t hear anything, feel for it if you can maybe with someone to help you may helpful. $W33T $0U7H3RN $UG4R
๐Ÿ‡ฌ๐Ÿ‡ง๐Ÿด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐Ÿด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐Ÿด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐Ÿ‡ฎ๐Ÿ‡ช๐Ÿ‡บ๐Ÿ‡ธโ›ฝ๏ธ๐Ÿ›ข๏ธโš™๏ธ๐Ÿงฐ๐Ÿ’ช
Post #947218 27th Mar 2022 7:32pm
The Anti Christ
Thanks for the suggestions everyone,
Everything's bolted or strapped down tight in the battery box tighter than a virgin's knees... definately something in the suspension..
Had an unprompted passenger comment on it on Sunday dureing a drive through the hills, saying she could feel it right under her feet...
A wheel bearing I think would be felt more in the steering, and calipers I would imagine would sound a bit more metallic.
@ Custom90Steve, am in agreement with your simulation approach... planning on getting some help tomorrow with rocking the van while I crawl under and look out for any play in the individual rubbers Just fix it before your friends find out it broke again - Landy Life Forever!
Post #947363 28th Mar 2022 10:33pm
The Anti Christ
Okay.... so over the last two days:
Tried changeing the left side radius arm bushings and rubber with no effect.
Realised afterward that there was movement in the top of the left schock absorber.
Both left and right top-most dampers seem to have melted right out into a black sticky goo.
The others werent very bad at all, however decided to change all eight while the shock absorbers were out.
Managed to use two of the old dampers that were in best shape on the steering damper on which the rubbers were half melted away also.
Changed two axle dust caps in the process and topped up joints with oil the caps seem to have just crumbled away, leaving the rusty axle spline center exposed to the elements.
Anyway.... I digress....Thudding sound gone! Bow down
Done and dusted!!!
Afterwards, got a once over at a wheel alignment garage which found no further wear and went ahead with the alignment.
Speaking of wheel alignment....has anyone here had issues with pulling to the left even after alignment? Just fix it before your friends find out it broke again - Landy Life Forever!
Post #947663 31st Mar 2022 11:58pm
Good news. ๐Ÿ‘๐Ÿป $W33T $0U7H3RN $UG4R
Post #947740 1st Apr 2022 5:23pm
spudfan
Ireland
It usually something simple, that is the nature of the beast. Finding it is the problem Laughing A good example of this is the issue I had with a reversing light and how it was sorted.
https://www.defender2.net/forum/topic81961.html 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #947750 1st Apr 2022 7:02pm
The Anti Christ
Yes indeed....
Had this same reverse light issue just after it came out of warrenty.... or noticed it then anyway...
The easiest way is through the top by removing the cubby.
The issue had a remarkabley simple fix once out: the switch is a mechanical ball and spring assembly.
Just needed a bit of WD40 and thumb rubbing... been working like new ever since.
...at least...i think....havent seen it in a while come to think of it...usually inside the van while reversing Confused
"The Land Rover Defender....Proudly turning drivers into mechanics for 70 years". Just fix it before your friends find out it broke again - Landy Life Forever!
Post #947765 1st Apr 2022 7:30pm
