Home > In Car Electronics > Headlights flickering |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17437 |
It wasn't a Britpart switch, by any chance?
Sounds like you need to change it again for a good one! |
17th Feb 2022 7:12am |
Will.I.AM Member Since: 16 May 2013 Location: Hertfordshire Posts: 417 |
lol yes sir!
thanks Black Wolf, tbh a guy on facebook literally just said the same thing that it is my fault for buying a cheap indicator stalk! Ill get a genuine on order now |
17th Feb 2022 7:15am |
so to resurect this thread guys - same issue with the new lucas unit and i also find that the interior lights dim at the same time as the headlights flicker - does anyone habve any pointers as to where to go first?
30th Mar 2022 5:44am |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2103 |
Sounds like an earth issue.
Do you know where all of your main earthing points are? If not, the learned folk on here will assist. Do you have a wiring diagram? |
30th Mar 2022 7:05am |
thanks Screbble, ill have a look later today.
30th Mar 2022 2:47pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20437 |
Front bulkhead engine bay side upper area and transfer box are typical locations for grounding points.
You could add a temporary ground directly to the headlights to see what that does. As well as checking voltage and continuity with a Multimeter if you’ve got one. Also a difference in voltage or continuity reading one side to another can be a tell tale. Some grounding eyes are on their own dedicated input on the same stud, so you can get good ground continuity with one but not the other but both share the same ground stud. When you are driving the connection is loose and give on and off contact hence the flickering you mention. Especially if it only does it when driving. A multimeter should be your friend here. Good luck. 👍🏻 $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
30th Mar 2022 4:32pm |
thanks Steve, i didn';t get a chance to check it last night but i think i will trace the earth wire form the battery tonight and clean up any contact points it goes to - once i have done that il check it with a short drive and if i still have the problem i think you idea of checking with a multi meter is a god one. Ill try that after and report what i find when i do it. thanks
31st Mar 2022 6:17am |
31st Mar 2022 1:16pm |
