Home > Wheels & Tyres > Tyre wear question |
Shroppy Member Since: 25 Feb 2016 Location: Shropshire Posts: 866 |
Do you have any photos / did you rotate your tyres? Would be a bit odd for the camber to be out on all for corners.. 1985 127 V8 Build Thread
Series 2 109" Series 1 80" |
30th Mar 2022 2:24pm |
NFIN02 Member Since: 17 Feb 2022 Location: Londonderry Posts: 96 |
Only have defender 6 weeks. Not sure if previous owner rotated to be honest. See image. Just concerned, don’t want my Cooper to shread off in the same fashion. Sorry pics not too good
30th Mar 2022 2:37pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3645 |
Possibly to much toe out on the front and the tyres have been swapped around DEFENDER 90 TDCI XS,
30th Mar 2022 2:43pm |
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 820 |
My money would be on the tracking being out and the tyres have been swapped front to back rather than getting it sorted.
Defender tracking is so simple it's almost foolproof, but some just get scared when faced with a 4x4. You can eyeball it for a quick dirty check, or get underneath and use an adjustable length pole between the front and rear edges of the rims. What ever you do, get it sorted before you wreck your new tyres. If DIY isn't your thing then find somewhere that specialises in truck and vans, the monkeys at Kwik Fit are sure to somehow screw it up! |
30th Mar 2022 4:55pm |
Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 970 |
On steering wheels, wear on the inside edges indicates towing out, on the outside either towing in or sometimes power steering feathering.
Not really sure if you have this on the rears unless they tyres have been repositioned historically to even out the wear… Ride like you stole it!! If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
30th Mar 2022 5:40pm |
30th Mar 2022 7:06pm |
Pleased with the 30mm spacers and coopers but get aligned at weekend to be sure!
30th Mar 2022 7:07pm |
I must have the younger sibling to this Click image to enlarge Ride like you stole it!! If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
30th Mar 2022 11:56pm |
Nice 90 👍🏻. Got everything lined today
31st Mar 2022 5:20pm |
