Home > Wheels & Tyres > Tyre wear question
NFIN02
United Kingdom 1989 Defender 90 300 Tdi HT Chawton White
Tyre wear question
Just got new set of coopers stt fitted this morning. Noticed when I was taking off my general grabbers they are significantly worn to the inside of all the Tyres. Any ideas. Alignment seems ok with driving but strange that all Tyres all badly worn.
Post #947503 30th Mar 2022 9:53am
Shroppy
United Kingdom 1986 Defender 130 V8 Petrol HCPU Aintree Green
Do you have any photos / did you rotate your tyres? Would be a bit odd for the camber to be out on all for corners.. 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #947517 30th Mar 2022 2:24pm
NFIN02
Only have defender 6 weeks. Not sure if previous owner rotated to be honest. See image. Just concerned, don’t want my Cooper to shread off in the same fashion. Sorry pics not too good
Post #947519 30th Mar 2022 2:37pm
LR90XS2011
Possibly to much toe out on the front and the tyres have been swapped around DEFENDER 90 TDCI XS,
Post #947520 30th Mar 2022 2:43pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
My money would be on the tracking being out and the tyres have been swapped front to back rather than getting it sorted.
Defender tracking is so simple it's almost foolproof, but some just get scared when faced with a 4x4.
You can eyeball it for a quick dirty check, or get underneath and use an adjustable length pole between the front and rear edges of the rims.
What ever you do, get it sorted before you wreck your new tyres. If DIY isn't your thing then find somewhere that specialises in truck and vans, the monkeys at Kwik Fit are sure to somehow screw it up!
Post #947537 30th Mar 2022 4:55pm
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
On steering wheels, wear on the inside edges indicates towing out, on the outside either towing in or sometimes power steering feathering.
Not really sure if you have this on the rears unless they tyres have been repositioned historically to even out the wear… Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #947541 30th Mar 2022 5:40pm
NFIN02
Post #947553 30th Mar 2022 7:06pm
NFIN02
Pleased with the 30mm spacers and coopers but get aligned at weekend to be sure!
Post #947554 30th Mar 2022 7:07pm
Leamreject
NFIN02 wrote:
I must have the younger sibling to this Thumbs Up
2011 2.4 Puma 90 HT
Post #947579 30th Mar 2022 11:56pm
NFIN02
Nice 90 👍🏻. Got everything lined today
Post #947643 31st Mar 2022 5:20pm
