Home > Maintenance & Modifications > Is hinge servicing an option? |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17458 |
Not really, it's well nigh impossible to get the pins out. Replacement is the cost-effective option.
29th Mar 2022 7:36pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3684 |
Thanks Blackwolf. Any tips out there on how to paint a set using rattle cans for longevity?
30th Mar 2022 4:59am |
Vitesse Member Since: 21 Mar 2014 Location: Sussex Posts: 386 |
Hi. I use occasional acf50 treatment to my hinges and have done for 7 years since new. No evidence of rust or wear as yet. 78000 miles. I recommend this for your new hinges π 2015 90 XS Santorini Black
30th Mar 2022 5:50am |
Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 970 |
When I bought my 90 most of the rear door hinges were seizing up, over time and plenty of light oil two out of the three have freed off nicely, the third is better but still tight so I have bought a spare to change at some point as Iβm told they are not serviceable Ride like you stole it!!
If Iβm not on a bike itβs because only a 4x4 will doβ¦ 2011 2.4 Puma 90 HT |
30th Mar 2022 7:21am |
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 820 |
I oil mine occasionally, maybe twice a year and this seems to work ok. Is this not as effective as the acf50? The problem is that they are commonly just neglected until they are a problem and at that point it is too late. |
30th Mar 2022 7:38am |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2248 |
Col, lubrication is a wonderful thing ππ
30th Mar 2022 8:03am |
Yes agreed. It has to be continuous really from new. I apply a little acf50 once month to all the hinges 2015 90 XS Santorini Black
30th Mar 2022 8:14am |
J1990 Member Since: 24 Aug 2021 Location: South West Posts: 39 |
I'd be interested in people's thoughts on the approach taken here - For the cost of replacing with OEM hinges I'm not sure I'd bother with the pin replacement, but fitting the grease nipple intrigues me as an easy monthly job to take care of.
&t=349s&ab_channel=Defendermodsandtravels |
30th Mar 2022 8:24am |
Interesting solution. probably works very well at forcing moisture out etc and would no doubt increase the life of the hinge... But in my opinion is suited more where the vehicle might be heavily used off road frequently .. Just my thoughts... 2015 90 XS Santorini Black
30th Mar 2022 3:43pm |
Mine are pretty regularly treated to ACF 50, but I fear that regularly using a foam degreaser to clean the car has negated the effect. Grease nipples might be an option on a new set, but itβs not exactly subtle! |
30th Mar 2022 3:48pm |
Forum stalwart Landroveranorak on here had the excellent idea of drilling a small hole through the centre of the hinge from a discrete angle as far as the centre pin, which allows the hinge to be greased with a chainsaw-type push-action lubricator.
It's a really neat, subtle, and effective solution and one I'd definitely do if I ever had standard hinges again. https://www.defender2.net/forum/post909912.html https://www.defender2.net/forum/post707394.html |
30th Mar 2022 4:45pm |
Thanks for the mention. The idea was unashamedly pinched from another member, Lightningtweeds, though
Here's the direct link to my solution: https://www.defender2.net/forum/post707394.html#707394 Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
31st Mar 2022 8:57am |
Shroppy Member Since: 25 Feb 2016 Location: Shropshire Posts: 866 |
If you're replacing the hinges anyway, I'd definitely go down the security/billet route from optimill or similar. Or at the very least get some hinge plates. I don't see why you couldn't pain them to suit, though you might want to request them in raw instead of anodised. 1985 127 V8 Build Thread
Series 2 109" Series 1 80" |
31st Mar 2022 9:54am |
Thanks LRA. Iβm going to have a crack at this on Saturday to see if I can catch them early enough. I really like the look of the original hinges, terribly security not withstanding! |
31st Mar 2022 5:14pm |
