Home > Puma (Tdci) > Where can I buy a replacement clip? |
Doodlefish Member Since: 18 Nov 2021 Location: United Kingdom Posts: 54 |
Click image to enlarge |
26th Mar 2022 8:50am |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3683 |
I would think a jubilee clip will be plenty enough to hold it rather than tracking down a clip. I think it is the breather hose from the rocker cover, but it’s hard to tell from the pic!
26th Mar 2022 8:56am |
Thx Co1.
The jubilee wont work as its a male connection to the rocker cover. You have to jubilee clip the hose onto a rigid plastic 'transfer' connector then push in the grommet seal end of it into the hole at the rocker cover. The clip assembly comes as one piece with an 'over' collar retaining it in position. Its the over collar that has snapped. https://www.defender2.net/gallery/albums/u...ition3.jpg |
26th Mar 2022 9:02am |
Gasket Member Since: 30 May 2020 Location: Manchester Posts: 629 |
Have you tried using the parts diagrams on the LRWorkshop site to find your clip?
https://www.lrworkshop.com/ Go to Menu/Diagrams/defender/ Then just start searching till you find it. If you create a free account you can enter your cars details so you’re only shown the relevant parts. |
26th Mar 2022 10:19am |
me your engine bay is clean!!
26th Mar 2022 2:32pm |
Great idea Gasket....but its not there
it should be a part where 12 is... Click image to enlarge |
26th Mar 2022 4:10pm |
Col1 - not my engine bay unfortunately
I dont trust anyone with an engine bay that clean... |
26th Mar 2022 4:12pm |
So you wont see the offending tape alternative Ive used beneath the rocker cover but you can just see the jubilee clip that fixes it to the part I need. The plastic element is seated ok into whatever hole its supposed to go to but there should be a flexible retaining collar I assume is to prevent it shooting off.
26th Mar 2022 4:27pm |
Is it part of the rocker cover assembly instead?
26th Mar 2022 6:23pm |
