Home > Td5 > Transfer Box swap - Hi/Low Sensor Switch
Woody3
United Kingdom 1989 Defender 90 200 Tdi HT Bronze Green
We are just swapping my mates 1.41 transfer box over in his Td5 Defender for a 1.222 Disco box (from a 300). However, we've hit a snag. There is no hi/lo sensor switch on the 1.222 box. What do we do?
Do we need to swap the casing over where the switch is located? Do we need the switch?
Any help would be much appreciated.
Thanks
Thumbs Up
Post #94682 17th Oct 2011 10:58am
ben_j85jty
United Kingdom 2002 Defender 110 Td5 XS DCPU Bonatti Grey
Yes - and No!
The front of the casing needs to be swapped, not a massive job and fairly easy to do.
As for needing it? It changes the throttle map to suit off road driving conditions, but is not essential. Tou could always wire a manual switch in aat a later date. 2002 Defender 110 DC
Post #94690 17th Oct 2011 12:10pm
I fitted an ex 300 disco t/box to my 110, never bothered with the switch; I don't (personally, you may disagree) like the "low range" throttle response.... 90% of it does hardly anything then the last 10% revs up to max throttle.
I think it's designed for people who havn't mastered the knack of holding their ankle still whilst going over rough ground and then kangarooing.
Post #94855 18th Oct 2011 1:24pm
T1G UP
did you link the wires jamie or leave them dangling
Post #94915 18th Oct 2011 7:09pm
marsie
England 2010 Defender 110 Puma 2.4 XS CSW Galway Green
Had the same problem when i fitted a 300 disco transfer to a mates td5. Planning on swapping mine after getting it remapped tomorow Mr. Green but will probably go for a disco td5 transfer and hopefully should be a more straightforward fit(providing i get one with difflock Rolling Eyes )
Paul Thumbs Up
Post #108860 21st Dec 2011 12:29am
bell-auto-services
Hi
You can do as mentioned leave them for later and fit a switch and it wont make any real difference to how it drives though im sure you can still have the switch fitted but may be in a slightly different location on the Tcase or a different switch is used I forget now.. I asume you are fitting a Disco box that still has diff lock ?
The low range map and switch is only used when in low range and in standard from does not make that much difference, Though I do use them on many cars for when I add a special map to it at remap time that gives even more torque for off road use.
Pete
Post #108863 21st Dec 2011 12:46am
