Home > Technical > TCS light coming on after steering wheel change?
exigesDB
Did I do something wrong ?
Today I changed my rubberised/PU steering wheel for a genuine leather XS style wheel. Both have the latest slotted steering angle sensor pattern on the underside, and the new wheel slotted nicely into place.. all good right ?
Except the TCS light now comes on when the car is driven. (The light illuminates at ignition 1 position, and goes out after the engine is started, but as soon as the car is driven and the steering is turned for the first time the TCS light comes on.)
I’ve checked that as the steering wheel moves the grey sleeve that the wheel keys into also rotates.
How do I trace the problem ?
Thanks in advance
Post #946209 18th Mar 2022 7:40pm
TJ101
steering angle sensor needs to be recalibrated , mine did the same when it was new California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #946226 18th Mar 2022 10:03pm
exigesDB
Many thanks for the quick response.. question now is how do I recalibrate the sensor ?
Post #946253 19th Mar 2022 10:09am
Nashvegas
United States
Prob need a dealer. I would take it in and they may not know you've changed out the wheel, and thus may do it under warranty Rolling with laughter
Post #946281 19th Mar 2022 4:55pm
exigesDB
To follow up on my own thread I managed to recalibrate the steering without needing to go to the dealer or using any specialist equipment, and I'm finally rid of the warning light..
Steps are as follows:
1. Make sure the front wheels are pointing dead-ahead
2. Remove the steering wheel
3. Start the ignition and rotate the grey forked sleeve on the steering column clockwise until the TCS light comes on. (That's where the car thinks its beyond full clockwise lock.)
4. Turn the engine off, and turn the grey sleeve half a turn anti-clockwise. (we do this otherwise the TCS light will come straight on again when the ignition is on)
5. Turn the engine on, and count the number of turns the grey sleeve needs turning anti clockwise until the TCS light comes on. (This is where the car thinks its beyond full anticlockwise lock)
6. Turn the engine off, and turn the grey sleeve half a turn clockwise (to match the half turn we performed in step 4)
7. Subtract 1 (to account for the two half turns) from the number of anti-clockwise turns and divide by two.. and then turn the grey sleeve clockwise by that number. The grey sleeve is now positioned exactly half way between left lock and right lock.
8. Re-attach steering wheel.
Post #946499 21st Mar 2022 5:04pm
webbug
United Arab Emirates 2016 Defender 110 Puma 2.2 SW Auto Alpine White
Apologies to bring this topic back, just found out that you are the only one in the universe who gave the right way to reset the TCS.
Still I wasn’t lucky to get it done, something might be done wrongly with my steps.
Let’s start with the two exposed plastics, are they spoused to be horizontal position when the steering is straight or vertically?
Post #1023393 3rd Feb 2024 5:17am
Oldowner
If you have or can borrow a Nanocom with the latest software update it will provide live data for the steering angle sensor, so you can position it to 0 degrees prior to refitting the steering wheel. It is hidden in a submenu, may be the ABS system.
I have had to recalibrate a 2015 one after a clueless garage changed the steering box and returned it with steering wheel at an angle.
Post #1023507 4th Feb 2024 3:14am
