Home > For Sale & Wanted > WANTED Disco TD5 ECU |
noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1195 |
As the title says Wanted a Disco 2 TD5 Engine ECU i know i am on the Defender site but anyone on the Disco sites please have a ask round for me Ta If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle Weekends 07MY L322 TDV8 Vogue SE Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
16th Oct 2011 6:46pm |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 |
what engine? 10p or 15p
auto or manual? |
16th Oct 2011 6:48pm |
I am looking for part no MSB101330 its been damaged in an accident squashed and the dent in the casing has shorted out the board inside If everything is under control you are not going fast enough.
16th Oct 2011 9:36pm |
sc70 Member Since: 29 Jun 2010 Location: Tregaron Posts: 261 |
i have one from a D2 auto not sure of part number but it is MSB
17th Oct 2011 5:56pm |
earlier 10p i guess, later ones are NNN |
17th Oct 2011 7:44pm |
wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581 |
Part number shows it is from a manual Discovery Td5 from YA288371 to 2A736339 VIN if that helps...
17th Oct 2011 9:48pm |
Yes it is a "Y reg" manual low spec cloth seats ect, has been written off and its a bit worse for wear than i first thought. Have spoken to a diesil god who knows his stuff, if i get the same part no all i have to do with an autologic or D4 is re-program the injectors and the security if i get one of the later revised part no's you have to use the D4 system to down load a patch from Land Rover and then do the injectors and security.
I have found one on e-bay for £70 but no idea what condition If everything is under control you are not going fast enough. Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle Weekends 07MY L322 TDV8 Vogue SE Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
17th Oct 2011 10:17pm |
The auto part no last 2 digits are different 1340 Auto 1330 Manual and yes they are different If everything is under control you are not going fast enough. Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle Weekends 07MY L322 TDV8 Vogue SE Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
17th Oct 2011 10:19pm |
Alive Tuning Member Since: 01 Mar 2010 Location: Louth Posts: 610 |
I have several 101330's on the shelf. Send me your damaged ECU, and I will transfer all injector codes, throttle type, and security code onto a replacement. Then it'll just plug in and go!
18th Oct 2011 10:30pm |
Many thanks for the offer, i might be getting back to you if today does not work. I have got an ecu from ebay and someone down the road has got autologic not so sure he knows how to do complex stuff like this, as i said i might be getting back to you. If everything is under control you are not going fast enough.
22nd Oct 2011 8:19am |
