Home > For Sale & Wanted > WANTED Disco TD5 ECU
noworries4x4
As the title says Wanted a Disco 2 TD5 Engine ECU i know i am on the Defender site but anyone on the Disco sites please have a ask round for me Ta If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle
Weekends 07MY L322 TDV8 Vogue SE
No Worries 4X4
Post #94560 16th Oct 2011 6:46pm
T1G UP
what engine? 10p or 15p
auto or manual?
Post #94562 16th Oct 2011 6:48pm
noworries4x4
I am looking for part no MSB101330 its been damaged in an accident squashed and the dent in the casing has shorted out the board inside If everything is under control you are not going fast enough.
No Worries 4X4
Post #94620 16th Oct 2011 9:36pm
sc70
Wales 2015 Defender 90 Puma 2.2 CSW Santorini Black
i have one from a D2 auto not sure of part number but it is MSB
Post #94737 17th Oct 2011 5:56pm
T1G UP
earlier 10p i guess, later ones are NNN
Post #94762 17th Oct 2011 7:44pm
wslr
Part number shows it is from a manual Discovery Td5 from YA288371 to 2A736339 VIN if that helps...
Post #94786 17th Oct 2011 9:48pm
noworries4x4
Yes it is a "Y reg" manual low spec cloth seats ect, has been written off and its a bit worse for wear than i first thought. Have spoken to a diesil god who knows his stuff, if i get the same part no all i have to do with an autologic or D4 is re-program the injectors and the security if i get one of the later revised part no's you have to use the D4 system to down load a patch from Land Rover and then do the injectors and security.
I have found one on e-bay for £70 but no idea what condition If everything is under control you are not going fast enough.
No Worries 4X4
Post #94790 17th Oct 2011 10:17pm
noworries4x4
The auto part no last 2 digits are different 1340 Auto 1330 Manual and yes they are different If everything is under control you are not going fast enough.
No Worries 4X4
Post #94792 17th Oct 2011 10:19pm
Alive Tuning
I have several 101330's on the shelf. Send me your damaged ECU, and I will transfer all injector codes, throttle type, and security code onto a replacement. Then it'll just plug in and go!
Post #94993 18th Oct 2011 10:30pm
noworries4x4
Many thanks for the offer, i might be getting back to you if today does not work. I have got an ecu from ebay and someone down the road has got autologic not so sure he knows how to do complex stuff like this, as i said i might be getting back to you. If everything is under control you are not going fast enough.
No Worries 4X4
Post #95589 22nd Oct 2011 8:19am
