Home > For Sale & Wanted > [Wanted] Bonnet with Spare Wheel Carrier
M.J.Persius
Scotland 2003 Defender 130 Td5 HCPU Alpine White
Hi all,
On the look out for a 300tdi or earlier bonnet with spare wheel carrier. Colour doesn't matter too much although white would be excellent.
Also would be happy exchanging my current white TD5 bonnet for the above.
Located South West Scotland but happy to travel to collect.
Many thanks
220306-232
Post #944766 6th Mar 2022 1:59am
seriesonenut
Hi
Have you thought about fitting the parts yourself?
I have fitted a couple over the years took an hour or so. All parts are normally available on line.Just a thought. 2010 XS USW
1957 Series One 88 diesel
1958 Series One 88 4x2
Post #944775 6th Mar 2022 8:23am
M.J.Persius
Had considered this although don't think the TD5 bonnet is up to the weight of the spare wheel.
Had also thought about getting a standard 300tdi or older bonnet and installing the mount myself although feel it may be cheaper and easier just to buy one with the mount already installed.
Cheers for the recommendation though.
Post #944781 6th Mar 2022 9:59am
300TDi CSW Phil
United Kingdom 1995 Defender 110 300 Tdi CSW Epsom Green
Wasn't there a point in time where it became illegal (or similar) to have a spare mounted on the bonnet due to obstructing the view etc. 1995 300 Tdi Epsom Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home
M0XQS
Post #944782 6th Mar 2022 10:06am
Moneypit
2004 Defender 110 300 Tdi HT Fuji White
Think I have a TD5 spec spare wheel on the bonnet kit somewhere in my unit, from memory it was made by Front Runner
Post #944864 6th Mar 2022 9:23pm
M.J.Persius
If it's something you'd consider selling then give us a message,
would be very interested.
Post #944996 8th Mar 2022 12:39am
And if you fit a pre Td5 bonnet (as in, a 300 one) onto a Td5 vehicle, there's not much gap between the rocker cover and the bottom of the bonnet.... especially with the plastic soundproofing in place... It'll rattle like a rattly thing if it touches. I had that problem with mine.
Post #945020 8th Mar 2022 9:27am
Moneypit
I'll have a look when I'm home at the end of the month, currently working at Europes most expensive hole in the ground in Somerset. I'll send you some pictures etc if you haven't got sorted by then
Post #945106 8th Mar 2022 9:23pm
M.J.Persius
That would be much appreciated. Cheers
Post #945115 8th Mar 2022 10:58pm
