Home > For Sale & Wanted > [Wanted] Bonnet with Spare Wheel Carrier |
seriesonenut Member Since: 19 Nov 2014 Location: Essex Posts: 1230 |
Hi
Have you thought about fitting the parts yourself? I have fitted a couple over the years took an hour or so. All parts are normally available on line.Just a thought. 1984 One-Ten CSW 2010 XS USW (sold) 1957 Series One 88 diesel 1958 Series One 88 4x2 |
6th Mar 2022 8:23am |
M.J.Persius Member Since: 03 Apr 2021 Location: Ayrshire Posts: 17 |
Had considered this although don't think the TD5 bonnet is up to the weight of the spare wheel.
Had also thought about getting a standard 300tdi or older bonnet and installing the mount myself although feel it may be cheaper and easier just to buy one with the mount already installed. Cheers for the recommendation though. |
6th Mar 2022 9:59am |
300TDi CSW Phil Member Since: 03 Apr 2016 Location: Bracknell Posts: 750 |
Wasn't there a point in time where it became illegal (or similar) to have a spare mounted on the bonnet due to obstructing the view etc. 1995 300 Tdi Epsom Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home M0XQS |
6th Mar 2022 10:06am |
Moneypit Member Since: 27 Feb 2018 Location: North Yorkshire Posts: 271 |
Think I have a TD5 spec spare wheel on the bonnet kit somewhere in my unit, from memory it was made by Front Runner
6th Mar 2022 9:23pm |
If it's something you'd consider selling then give us a message, would be very interested. Cheers |
8th Mar 2022 12:39am |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6112 |
And if you fit a pre Td5 bonnet (as in, a 300 one) onto a Td5 vehicle, there's not much gap between the rocker cover and the bottom of the bonnet.... especially with the plastic soundproofing in place... It'll rattle like a rattly thing if it touches. I had that problem with mine.
8th Mar 2022 9:27am |
I'll have a look when I'm home at the end of the month, currently working at Europes most expensive hole in the ground in Somerset. I'll send you some pictures etc if you haven't got sorted by then |
8th Mar 2022 9:23pm |
That would be much appreciated. Cheers |
8th Mar 2022 10:58pm |
