Home > My Defender > What Did You Do In Your Defender Today |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4799 |
So having had the exterior Optimill door handles fitted by Roy5695 a couple of weeks ago to join lots of already fitted Optimill bits I felt it was time to add a few more Optimill bits today. The quality of their items and the customer service is always first class.
Interior door pulls and surrounds Interior handles Seat recliner handles Right hand side vent Window blocks Numberplate light. Then time to service the Ore 4x4 wheel carrier following an email from them reminding owners to ensure it’s kept greased. Another great company to deal with with excellent customer service. Then replacement of the rear mudflaps brackets after Scott of Uproar 4x4 kindly recoated mine for me again excellent customer service. And a mention of Labcraft for kindly sending a replacement Scenelight a couple of weeks back. We are very lucky to have such great companies with great customer service Then a quick wash with Optiwash. So the defender is looking good as the mileage hits 96000 tomorrow. Click image to enlarge Click image to enlarge 2015 HT XS 90 2008 SVX 90 2000 XS TD5 90 |
27th Feb 2022 3:54pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3686 |
Looking tidy indeed Suli, nice work.
28th Feb 2022 6:09am |
ChrisDefender Member Since: 29 Oct 2015 Location: Midlands Posts: 456 |
Great looking truck Sulisuli and I agree, there are some great people out there
28th Feb 2022 9:21am |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10830 |
Very nice Simon
It seems like i haven't seen the 90 in the flesh for a long time now Clayton. 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
28th Feb 2022 9:32pm |
Thanks all. Clayton would be great to catch up with you and join one of your greenlaning days again. 2015 HT XS 90
28th Feb 2022 10:10pm |
Clayton.
3rd Mar 2022 8:56pm |
So big day today, MOT and full 96000 mile service all oils including transmission and axles changed at my main dealer Roger Youngs.
Passed the MOT with no advisories at all I’m sure it drove so much better on the way home, even though I have it serviced every 6000 miles. Brilliant service and an excellent price too so very happy. 2015 HT XS 90 2008 SVX 90 2000 XS TD5 90 |
7th Mar 2022 8:38pm |
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 902 |
Got up early and dropped off the 90 for some work and MOT with Venture 4x4.
Click image to enlarge Charlie 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
7th Mar 2022 8:45pm |
Good news Simon with the MOT and i would agree to that they do drive back better from having a service Clayton. 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
7th Mar 2022 8:51pm |
alexatnd Member Since: 19 May 2015 Location: Yorkshire Posts: 281 |
Today think ive finally cured the oil leak from my turbo drain pipe/turbo gasket
Found that you get M6 bolts with 8mm head ( old lr turbo drain pipe) and M6 bolts with10mm heads ( new bolts) Also discovered that as I was bleeding the coolant system through the expensive top td5 radiator hose that has a metal bleed screw and threaded insert ...... it leaked past the threaded insert necessitating a new top radiator hose. Also foiud out quickest way to fit hose on top of thermostat is to remove the viscous fan first A Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road... almost Effie - 2004 110 TD5 County |
10th Mar 2022 1:02pm |
ok, almost cured it
10th Mar 2022 1:34pm |
Gasket Member Since: 30 May 2020 Location: Manchester Posts: 629 |
I have a Wright off road kit sitting in its box ready to fit to my puma 90SW. Gearing up to fit it, I've been umming and aahing about trying to put dynamat underneath but was worried that the additional thickness would stop the matting sitting neatly into/around the corners. Drew said it wasn't worth it, but I'd rather go belt and braces. Did the mat fit OK? For ease and speed, I've been looking at the pre-cut Dynamat pieces from Britpart (DA8083 and DA8084) so at least they don't go into the corners. |
10th Mar 2022 8:54pm |
300TDi CSW Phil Member Since: 03 Apr 2016 Location: Bracknell Posts: 750 |
Whilst up visiting family in Leeds took a trip over to Halifax to pick up a cargo bear rack and some accessories from Brendan at 4x4 overlander.
I've spoken with both Brendan and Barbara a few times over the years and bought various bits from them but to say it was a pleasure to finally meet face to face and have a coffee with Brendan and a chin wag is an understatement. 1995 300 Tdi Epsom Green - It's a keeper. Wide Track Sankey- In bits- Gone to a new home M0XQS |
12th Mar 2022 7:46pm |
judders Member Since: 28 Jul 2021 Location: Basingstoke Posts: 23 |
Wheel and tyre upgrade. Wasn't planning on doing things in this order, but the 235 Contis were starting to look ropey and needed replacing, so kinda forced my hand. Still, very happy with the end result anyway.
Shiny black wheels make all the other black stuff look a bit drab though, so probably need to address that now. I'll add it to the list. Click image to enlarge Click image to enlarge Click image to enlarge |
19th Mar 2022 11:52pm |
