Home > Maintenance & Modifications > LT230 advice |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3387 |
Fit the bearing to the shaft first, and then install.
I generally use a drift punch to tap bearings if I do not have the right size of tubes to fit in a press. Always tap or press on the race that is being fitted, for example fitting bearing to shaft, tap on the inner race only. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
26th Feb 2022 7:51pm |
mini Anaconda Member Since: 23 Aug 2016 Location: Thames Valley Posts: 776 |
Thank you BORG - Bucks & Oxon 4x4 Response Group
27th Feb 2022 6:53pm |
