- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Penfold_6290
I don’t know how it may have failed except for the usual contamination by dirt, water or road salt. The connector on the loom is YPC10070 which is the same as the crankshaft speed sensor and many others on the vehicle. If you search Ebay for item number eBay Item No. 143412803593 you will find the plug, crimp terminals and sealing plugs. Should be everything you need to replace the plug if you think it’s causing the fault.
You’re going to have to do some dismantling to get to the loom in order to repair it, probably transmission tunnel out which isn’t too bad a job, just time consuming. Probably easier than struggling to do it at arms length from underneath.
23rd Feb 2022 9:31pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
