![]() | Home > Maintenance & Modifications > Propshaft Safety |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4761 ![]() ![]() |
Noted
![]() 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 ![]() ![]() ![]() |
please correct me if I'm wrong, but I thought that with the centre diff locked the hand brake works on both axels, could it be that the diff lock wasnt in, was the light on?
Mark |
LESVOSD110 Member Since: 19 Aug 2009 Location: South Africa Posts: 241 ![]() ![]() ![]() |
You are correct.With diff lock engaged and hand brake,the defender will not move with no rear prop. Puma 110 SW 90 V8 SOFT TOP |
I did not know that, so the drum transmission brake works on the output shaft of the xfer box and with the xfer box locked this would in effect lock the transmission and stop the vehicle from moving.
i must admit as soon as the vehicle started to move I knew immediatelty what was wrong - just a bit late. i think chocking the wheels is also a sensible thing to do when working on the transmission. |
Good post and duly noted.... On a lighter note, 'still here' you are (thankfully), tme to 'man up' wipe your minge and move on to the next faux pas! ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
