Home > Maintenance & Modifications > Propshaft Safety
Propshaft Safety
From time to time, I do some really dumb things but, this morning was positively dangerous.
when you change your rear propshaft (on my 90)
1. chock you vehicle
2. put it in low range and lock the xfer box
3. put it in gear
4. have someone to help you
this morning, i though it would be straight forward task to change the rear prop. i even have the propshaft extension socket to make the job easier but ended up nearly killing myself. took off all the bolts and removed prop - the car started to move... the hand brake works on the rear prop, take off the rear prop - NO HAND BRAKE. Luckily I am here to tell the tale but it did frighten me somewhat.
Post #94341 15th Oct 2011 10:40am
spudfan
Ireland
Noted Thumbs Up 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #94347 15th Oct 2011 10:58am
double cab happy
England 2007 Defender 110 Puma 2.4 DCPU Java Black
please correct me if I'm wrong, but I thought that with the centre diff locked the hand brake works on both axels, could it be that the diff lock wasnt in, was the light on?
Mark
Post #94352 15th Oct 2011 11:59am
LESVOSD110
South Africa 2010 Defender 110 Puma 2.4 SW Fuji White
Mark
You are correct.With diff lock engaged and hand brake,the defender will not move with no rear prop. Puma 110 SW
90 V8 SOFT TOP
Post #94354 15th Oct 2011 12:04pm
I did not know that, so the drum transmission brake works on the output shaft of the xfer box and with the xfer box locked this would in effect lock the transmission and stop the vehicle from moving.
i must admit as soon as the vehicle started to move I knew immediatelty what was wrong - just a bit late.
i think chocking the wheels is also a sensible thing to do when working on the transmission.
Post #94357 15th Oct 2011 12:23pm
K9F
Re: Propshaft Safety
Good post and duly noted.... On a lighter note, 'still here' you are (thankfully), tme to 'man up' wipe your minge and move on to the next faux pas! Rolling with laughter
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #94360 15th Oct 2011 12:42pm
