Home > Technical > Adwest 4 bolt steering box overhaul |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2286 |
Hmmmm I think this job might be beyond my ability/tooling! > 110 XS Double Cab
19th Jul 2021 1:35pm |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 615 |
If you are just replacing the sector shaft and seals / bearings, or the input/ worm shaft seal, you can get away with not disturbing the rack / plunger assembly as long as you make a note of alignment
19th Jul 2021 8:24pm |
jfh Member Since: 08 Jan 2014 Location: West Coast Posts: 356 |
Is that for the worm? I have a dismantled box, I wanted to overhaul it but the worm was a £1000 if I convert our currency yo Pounds. So I just bought a new one. But at that price it might be worth it. |
20th Jul 2021 5:38pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3383 |
RTC4405 is the worm for right hand boxes which should be the one you need for SA. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
20th Jul 2021 7:06pm |
Hi.
Does the sector shaft take 2 bearings in the bottom part? I stripped the box but only found one. |
16th Feb 2022 5:26pm |
Yes, 2 bearings at the bottom. See below that oldowner kindly shared.
1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
16th Feb 2022 5:39pm |
Thanks, I did read this post but just wanted to confirm.
This might explain why my sector shaft has damage. The grind and hard chrome is luckily much cheaper than a new one. |
16th Feb 2022 5:50pm |
Another question about the bearings.
The top bearing of the of the bottom 2, is it installed flush or recessed a bit? |
17th Feb 2022 6:40am |
Ignore that mine is a bronze bush and not a needle bearing, but that top bearing goes flush with the top of the casing. It might not be perfectly flush, as the top facing of the casing is not machined there. The sector shaft will not rub, as it should be blocked from going further down by the follower wheel resting on the worm.
Care when putting the top cover back in, as it is easy to make a flat spot on either the worm or the following wheel if the top cover is bolted down is the backlash adjustment screw is not fully out (lifting the sector away from the worm). 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
17th Feb 2022 7:38am |
Thank you very much.
17th Feb 2022 8:01am |
Would be interesting to find why one of the lower bearing was removed.
Could it be that the sector shaft is bent, and one of the lower bearings was removed to get the top cover to fit? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
17th Feb 2022 9:02am |
Not sure, I'm second owner.
Owned her for 10 of the 16 years. |
17th Feb 2022 9:13am |
Buttons Member Since: 24 Nov 2018 Location: Galway Posts: 34 |
Brilliant info.
I've just finished, (well almost as the worm/valve assembly had been ground down so the seals in the kit do not fit, not a big deal but I'll have to order correct sized seals), the rebuild of my steering box including the teflon seals. The large diameter one on the piston was easy to fit, heat up and slip over, but the smaller ones on the worm/valve were very scary as I'd never done this type of thing before. After crafting an 'expander tool' from a plastic wine glass, fruit packaging and tape and attempting to fit - it was dumped, don't bother. I heated the seals in a bowl of water in the microwave to boiling and then fitted using a cocktail stick, (a decent diameter fishing line in a loop would probably do too). It was quite easy but a lot scary. I shrunk them with a 'collar' from fruit packaging to even out the compression and a standard worm clip. Turned out perfect. Its a bit worrying when the seals are loose on the shaft after fitting but they do shrink back when compressed. I tapped out the original needle bearings but reused them as they are in good condition. All seals/bearings on my box are imperial. |
20th Mar 2022 2:50am |
