![]() | Home > Technical > Front wheel position |
![]() Click image to enlarge How far your tyres sits to the back depend on the lift you have. These are also 35" but I modified the wheelarces a little to be able to drive off-road. I have about 7 cm suspension lift. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
shanecl Member Since: 20 Mar 2013 Location: Louth Posts: 518 ![]() ![]() ![]() |
Thanks for the pic Roel, looks awesome truck
I've standard springs in mine ![]() ![]() |
Hufflepuff Member Since: 25 Oct 2014 Location: Hampshire Posts: 727 ![]() ![]() ![]() |
Slightly off topic I appreciate, but I'm keen to know which 35" tyre sizes are you both using, and what rim offset to be able to fit under the standard arches (albeit with a little snip on Roel's edges)? 2005 Td5 90 XS
1989 V8 110 CSW |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3387 ![]() ![]() |
I have approx 95mm clearance on mine.
Thats with a 50mm lift however and +50mm arches on ET-32 Wheels. Tyres are 315/75/16 BFG KM3 I'd think wheels with less offset would start to limit steering lock. @roel - are yours 10.5 or 12.5 width? ![]() Click image to enlarge ![]() |
I'm running a different setup then normal. Gold star if you guess 🤣🤣 ![]() Click image to enlarge ![]() Click image to enlarge Reason I asked I wanted to see what it's meant to be on a normal defedner ![]() Click image to enlarge |
Thanks Camelman, looks like your centre cap is running in line with the centre of the wheel arch. I may have to do some correction on mine ![]() |
Oh, Toyota axles? OK that explains that ![]() 1989 V8 110 CSW |
Sorry Disco 2 axles
Oh well, I guessed wrong
![]() Click image to enlarge These are 35 x 10,5 x R16. The rims are 8J ET 0 I believe. This all is a bit wide for the standard arches but still have a good turning circle. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
Thanks Roel. So potentially ET10 would make them a bit more 'legal' in the UK where the tread must be within the bodywork, although this would likely depend also then on what tyres you were running. 2005 Td5 90 XS
1989 V8 110 CSW |
We'll give a silver star for effort ![]() ![]() ![]() ![]() |
A quick measurement: The outside off the widest block on the tread sticks 20 mm out and the widest part off the tire about 35 mm. This is probably also not completely legal in The Netherlands as the tire is allowed stick out 30 mm and the track width may only be increased by 2%. But it looks like they only stop tuned cars for that. ![]() 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
