![]() | Home > Technical > R380 gearstick housing assembly |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5871 ![]() ![]() |
Yes pin comes out both sides so you can line stick up with in the gearbox gate.
Hufflepuff Member Since: 25 Oct 2014 Location: Hampshire Posts: 727 ![]() ![]() ![]() |
Ah I didn't think to look at SynchroGearboxes, they even have videos detailing the whole assembly, awesome thanks Andy!
Now to find someone which sells the pin... 2005 Td5 90 XS 1989 V8 110 CSW |
Shroppy Member Since: 25 Feb 2016 Location: Shropshire Posts: 868 ![]() ![]() ![]() |
I should have a spare lever (FRC8724) if you need one, I doubt you'll find the pins separately.
The plastic plunger (22G1988L) and the spring (22G1989L) are the only parts which fit into the lever, you haven't lost anything. ![]() Series 2 109" Series 1 80" |
Yes looks like the pin is not sold separately. I could get the knobbly bit between £65 and £200, but decided to bite the bullet and get the complete kit from synchro-gearboxes, at:
https://www.onlinegearboxparts.com/product...d5-bundle/ This also includes a new turret (they say these can wear), the foam bit which I don't have (sound deadening?) and one of their reduced throw assemblies. I'm not a huge fan of reducing the throw if I'm honest, I don't find it particular long on the Td5, but this seems the most economical way of getting the whole lot in one go. 2005 Td5 90 XS 1989 V8 110 CSW |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2187 ![]() ![]() ![]() |
Good choice Hufflepuff - it’s on my ‘to do’ list.
Like you I’m less bothered about the ‘throw’ but would like a more positive and ‘less worn’ gear changing experience ![]() That said, I expect I would probably like the shorter throw as many others have commented on how good it feels. Let us know how you get on. |
