Home > Maintenance & Modifications > 110 Rear diff damage |
davidblythe Member Since: 27 Apr 2019 Location: Cheam, Surrey Posts: 110 |
found 2 snapped heads and swarf when doing a rear diff oil change, stripped axle down, can see the snapped bolts on crownwheel and associated damage
Anyone have any ideas why bolts have snapped, this has been in place for 3 years and no damage on last oil change 5k miles before Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge 1999 90 TD5 CSW 2006 110 TD5 HD Commercial |
12th Feb 2022 2:29pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3670 |
That is bizarre to see a failure in that form. I would suggest as above that they were over torqued during assembly and that the root cause of the damage was actually done back then. Would be worth checking what the others are torqued to to confirm this.
13th Feb 2022 7:56am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17337 |
I seem to remember that someone else on here reported a similar failure but at the front not long ago.
It's hard to know the cause without seem the fracture face of the two broken bolts (the loose bits are too mangled, but the threaded bits should be clear), but it is an unexpected failure. Last edited by blackwolf on 28th Mar 2022 11:44am. Edited 1 time in total |
13th Feb 2022 8:08am |
ashtrans Site Sponsor Member Since: 08 Nov 2008 Location: Harpenden Posts: 257 |
we see this failure very often on the 110 rear which it why we upped the bolt thread on our HD hypoid diff, Dave
21st Feb 2022 7:35pm |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 616 |
A had simillar problem on fron diff of 110. And have seen it quite a lot of passenger cars with strong diesel engine. "Drobek" = The Small One - Discovery 2, "BlufĂnek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
21st Feb 2022 7:57pm |
