Home > Puma (Tdci) > Random Electrics
James Weston
United Kingdom 2007 Defender 110 Puma 2.4 HT Rimini Red
Random Electrics
Evening all.
I have noticed that when I go over a harsh speed bump or hit a pot hole the radio/ blowers and centre console backlights go off.
After switching it off and on they all work again.
All fuses checked and are good!!
Could it be a bad earth and if so where are they??
Any ideas are much appreciated 👍🏻🙈
Post #940685 2nd Feb 2022 5:36pm
AndyS
There's an earth cable in the driver's side wheel arch to the chassis. No idea if that's the issue but it's easy to check.
Post #940710 2nd Feb 2022 8:44pm
Gasket
I had the exact same issue a few weeks ago after the car had been in for some work.
Turned out the negative battery lead had come off the terminal and it was only the spring-back of the cable that was holding the cable against the terminal.
Followed an excellent tip from the forum to use some copper shim around the battery terminal to allow the clamp to really take hold. That fixed it.
Post #940732 3rd Feb 2022 12:13am
jpboost
United Kingdom 2014 Defender 110 Puma 2.2 SW Keswick Green
My backlights come on/off/flicker as I rotate the heater output direction control around. I've not had a look yet, but whatever the bad connection is, it is definitely local to that area. So don't rule out something in or close to the panel.
Sorry, no answer for you, but I'll come back and update when I get a chance to pull it apart and investigate.
Post #940744 3rd Feb 2022 8:44am
James Weston
Just taken all earths off the bulkhead under the bonnet and cleaned them. Still no better.
Ran out of daylight so will see what I can find at the weekend.
Also, what is the green box(ECU) that is next to the fuses under the dash?
There is an orange with grey striped wire not connected in the plug
Post #940832 3rd Feb 2022 6:08pm
That's the AS10 alarm unit. Darren
Post #940893 4th Feb 2022 6:48am
James Weston
Thanks for letting me know, I will see if I can fine where the wire is supposed to connect to know.
UPDATE on the Orange wire from the ECU...... It isn't supposed to be connected as it is acting as an Aerial
But still no further on with the other electrical gremlins Confused
Post #940895 4th Feb 2022 6:50am
Martin
Site Admin
It doesn’t attach it’s the aerial.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #940896 4th Feb 2022 7:03am
