Home > Puma (Tdci) > P0101 Fault Problem
Doodlefish
P0101 Fault Problem
Anyone have an idea why I might have a P0101 Air mass fault only under boost (i.e 60mph)? Below this it runs perfectly.
Post #940614 2nd Feb 2022 8:57am
The typical reason is a split in the intercooler pipework or sometimes the intercooler itself. Darren
Post #940619 2nd Feb 2022 9:26am
Doodlefish
Intercooler has been replaced and all but the hard to reach pipework are silicon replacements. I plan to see what remains of the original rubber pipework and check/replace those too.
Post #940620 2nd Feb 2022 9:29am
Unfortunately, the hard to reach bits are also quite often the culprits. Darren
Post #940622 2nd Feb 2022 9:32am
Doodlefish
I agree. I am not sure what rubber pipes are even left. My engine bay is a sea of blue pipework Laughing
Post #940623 2nd Feb 2022 9:34am
Martin
Site Admin
P0101 covers a variety of MAF-triggered OBD faults, what's the full code?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #940633 2nd Feb 2022 12:01pm
Doodlefish
I dont have any further code details. My OBD reader is fairly basic. It simply reads "P0101 - Powertrain Mass or Volume Air Flow Circuit Range / Performance Problem"
I have a new MAF sensor, Intercooler and most of my hose kit is new silicone. Wiring tested and good.
I was hoping someone had an idea based on the specific symptom of being perfect till 60mph (or there abouts).
Post #940635 2nd Feb 2022 12:09pm
Nino4x4
Spain
Fault p0101 is usually given when there is an aspiration problem and the air requested by the ECU does not coincide with the air sucked in.
Do you have the vehicle remapped?
do you wear snorkels?
Also check the air filter.
Post #940642 2nd Feb 2022 12:52pm
Doodlefish
No remapping
I do have a snorkel for about a year now
New Air Filter is fitted
Post #940643 2nd Feb 2022 12:55pm
110NTK
By any chance does your air filter get wet in rain/very dirty.
I was getting this a lot, took the air intake grate off the drivers side and the plastic was all loose, hooked it all back up touch wood it’s been fine since (MY13 110 Sw)
Post #941017 4th Feb 2022 7:19pm
Doodlefish
Inconsistency
Fitted a new connector to the MAF sensor and very carefully soldered all the new wires back into the loom. Test drive for 20 mins or so and at 70mph on dual track pinged the EML fault code P0101. Pulled over with engine running and cleared fault code off. Did same trip and tried to do exactly the same thing to work out at what point the EML lights and it ran like a dream. No faults. WT..hell.
Any ideas?
Post #941111 5th Feb 2022 2:02pm
Martin
Site Admin
Need to get a more specific fault code as otherwise you’re just guessing.
Might be worth a low pressure or smoke test to check you don’t have any tiny boost system leaks.
Was a thread on here in past week or so about using a bike pump adapted to turbo compressor outlet hose to pressure test.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #941134 5th Feb 2022 4:33pm
Doodlefish
Update
So, last weekend I took the old girl for a test run with a carefully soldered wiring to a new MAF connector (easy and cheap change just in case the connector was dodgy). I drove for 20 mins without EML and then bit the bullet and pushed it on dual carriageway. At 70mph it held for a couple of minutes before the EML and P0101 popped up. We reset and went on same journey without a repeat of the EML or fault.
I have now driven the defender daily and have covered 100 miles since the weekend including a 20 mile motorway stint and several steep up hill full throttle blasts to push for the fault. No fault has occurred since then.
This weekend I will be going over the 'air' pipework with a fine tooth comb and am trying to source a smoke test as advised in case of a small split somewhere. BUT, regardless of the fault code, why on earth would it be so inconsistent? I cannot repeat the fault in exactly the same circumstances, which makes me feel like I have one foot on a mine Laughing
Again, happy to hear any advice.
Post #941748 9th Feb 2022 8:58am
EGR issues, can sometimes create phantom MAF DTC’s. There can also be nuisance MAF DTC’s caused by having a RAI or Snorkel.
This isn’t something that I’d had with mine, but I have heard about it before something that some people have had happen and others haven’t.
Is the filter in good nick, not an oiled type? It has been known for like d air filters to have oil migrate from the filter and contaminate the MAF and also cause restriction.
Personally I don’t think you can beta genuine air filters replaced at servicing. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #941843 9th Feb 2022 8:39pm
Doodlefish
HI Steve
Thanks for responding. So, we have a new air filter, new maf sensor and new EGR valve and all genuine replacements.
The EGR valve could be sticky but its been working fine for the last 100 miles and in any case it seemed only to occur at over 65 mph in 6th gear rather than associated to boost in lower gears.
Is it even possible that the new fittings have needed to 'bed' in with the ECU? Does the ECU need to acclimatise to the new equipment?
In any case, no EML for 100 miles and counting but bizarre.
Just to fill one gap, I have had a new intercooler (genuine standard) as all this started when I blew the seam on the old one during a long motorway run.
Post #941845 9th Feb 2022 8:48pm
