Home > Td5 > New Engine Noise
Landlord
United Kingdom 2007 Defender 90 Td5 HT Cairns Blue
New Engine Noise
Hi All
Had my TD5 for 14 years and never missed a beat, very reliable. Have been using it for commuting recently and have started to notice a ticking noise from the engine. Some history;
Vehicle is one of the last TD5's built. Has now done 78k and regularly serviced. Yes some modifications including remap about 11 years ago which has been superb. Starts immediately in all weathers, engine temperature normal, no smoke from exhaust, no unusual smells or leaks, fuel consumption unchanged, still pulls like a train in all gears.
New noise is a ticking metallic noise, speed of ticking increases relative to RPM, not loud but I can hear it. Bit like tappets in an old OHV engine. I'm guessing cam followers or timing chain. Anyone out there come across similar / is timing chain a service item / are cam followers a service item ?
Need your input on this one as scratching head ! 2007 TD5 90 Hard Top
Post #940465 1st Feb 2022 7:24am
lightning
Are you sure it's not an exhaust gas leak? Check the manifold for leaks and also the flexible joint on the exhaust down pipe for cracks
Post #940498 1st Feb 2022 12:11pm
excossack
Turbo heat shield? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #940500 1st Feb 2022 12:16pm
Landlord
Will check both suggestions but don’t think it’s exhaust manifold but you never know.
Just ordered a new oil centrifugal filter as this could become defective and cause similar noise.
Will start with basics before taking cam cover off. 2007 TD5 90 Hard Top
Post #940509 1st Feb 2022 12:35pm
Ianh
You could go old school and get yourself a mechanics stethoscope, ie Lisle 52500.. cheaper ones out there but they don’t perform as well. Great for locating where noises are coming from.
Post #940515 1st Feb 2022 1:23pm
BaronDefenders
United Kingdom 2004 Defender 90 Td5 CSW Santorini Black
Could be one of a number of things.
Best thing would be to stand by the engine whilst someone revs it. Then you can try to locate the noise more accurately.
Check the pulleys, as they can make odd noises.
The hydraulic lash adjusters can make tapping noises, but usually that is most noticeable at idle.
Hopefully it’s something simple and easy to resolve. Charlie
1949 Series 1 80 (SOLD)
2002 Td5 90 (SOLD)
2008 Freelander 2 (SOLD)
1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored)
1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE)
2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK)
2012 Puma 110 Zermatt Silver (Overlanding Build)
Instagram: @BaronDefenders
Post #940551 1st Feb 2022 6:13pm
mini Anaconda
Watching the thread with interest as I am also trying to investigate a similar issue which is leading to a lot of head scratching! Confused BORG - Bucks & Oxon 4x4 Response Group
Post #940600 2nd Feb 2022 6:54am
M.J.Persius
Scotland 2003 Defender 130 Td5 HCPU Alpine White
Following also.
155,000 miles with a very similar issue that intermittently presents around 2500rpm.
Post #944764 6th Mar 2022 1:35am
Landlord
Might have found the issue - and its not the engine.
Will know more in a few weeks. Still drives perfectly so not a major issue just curious.
Will report back once diagnosed 2007 TD5 90 Hard Top
Post #945354 10th Mar 2022 9:46pm
Landlord
Problem found...
Spigot bearing at the end of gearbox output shaft completely disintegrated. Output shaft then suffered with excessive play causing the noise to be transferred through engine and therefore difficult to pinpoint.
New gearbox from Ashcroft Engineering installed along with their upgraded billet release bearing, new clutch and pressure plate (as a precaution) and new spigot bearing.
Noise gone, gearbox tight and Landy drives like new again.
Just put through yearly MOT and passed first time.
So now its sorted it is a pity that it will be going up for sale soon. After nearly 15 years of ownership it is time for someone else to enjoy a great Defender. 2007 TD5 90 Hard Top
Post #955971 19th Jun 2022 8:47pm
