Home > Wheels & Tyres (L663) > TPMS - dumb question re using spare wheel
BruceT
South Africa
Hi all,
if I rotate my tyres using the spare wheel, would I need to rotate the TPMS sensors also?
Does the spare wheel have a TPMS sensor?
sorry if these are dumb questions
Thank you "Overlanding With Bruce" - Youtube https://www.youtube.com/@OverlandingwithBruce
11MY Defender 130
23MY Defender 110 D300 HSE X-Dynamic
https://www.youtube.com/channel/UCzrHKcjA-LJ470_H4QwPgVA
Post #940459 1st Feb 2022 6:20am
Tim in Scotland
If your spare has a silver/grey valve stem then it has the sensor, if it’s black then no, the sensors are not linked to a particular tyre.
I had to put my spare on the front near side wheel last year. I put it on the hub, torqqued it up and drove away and the dash alarm went off in a few seconds……….. the app though is still telling me I have a puncture 6 months later! I know of at least one 110 where the spare doesn’t show on the dash readout but mine does, with a recommended pressure of 50 psi with the stupid alarm going off at 48psi so even winter temperatures set off the low pressure warning here……… good job I have a decent electric tyre pump. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #940479 1st Feb 2022 9:42am
BruceT
South Africa
Thank you Tim In Scotland. That is a great help. "Overlanding With Bruce" - Youtube https://www.youtube.com/@OverlandingwithBruce
11MY Defender 130
Post #940502 1st Feb 2022 12:21pm
martinf
According to page 428 of the Defender Handbook, "The spare wheel pressure is not monitored"
Post #940504 1st Feb 2022 12:29pm
Tim in Scotland
MartinF - have a check, sure does in my June 2020 D240 First Edition. The car I saw it wasn’t monitored in was a 2021 D250 SE but the wheel/tyre did have a sensor as it had the grey/silver valve stem.
Post #940520 1st Feb 2022 2:02pm
martinf
Very odd! My 110 HSE MY2022 is consistent with the sentence I found in the handbook.
Although my valve stems are all the same they are black rather than silver.
Post #940531 1st Feb 2022 3:07pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
That's not entirely correct, I just fitted a set of LR steel wheels yesterday and this valve shown in the photo is a TPMS valve, it's black and is a rubber stem Thumbs Up
 Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #940532 1st Feb 2022 3:12pm
Hairy Dan
Also just been out and had a look, mine's a MY2022 and it doesn't have the pressure reading on the dash for the spare Confused
 Cheers Ian
Kielder 4x4 Safari
Post #940534 1st Feb 2022 3:19pm
J77
My one doesn’t show the tyre pressure for the spare, but having put my spare on, the car picked up the new wheel within a mile of driving. 24MY 90 D250 HSE, Tasman Blue
Post #940574 1st Feb 2022 7:56pm
BruceT
South Africa
thank you all for the replies. I do have a sensor on my spare wheel which is silver and the display does show its pressure. Was more worried about if the sensors need to stay in the same positions to give accurate readings.
Here is my display:
11MY Defender 130
Post #940602 2nd Feb 2022 7:05am
