![]() | Home > Faults & Fixes (L663) > Rear glass - burst |
Was the heated elements turned on?
mse Member Since: 06 Apr 2008 Location: UK Posts: 5068 ![]() ![]() ![]() |
I had this on my puma 90 I recall, they replaced under warranty…but many things different Mike
misha1976 Member Since: 29 Jan 2022 Location: minsk Posts: 8 ![]() |
heated elements turned OFF |
PHOTO same story with burst glass in Moskow ( defender 90 -l663) :
Some toughened glass can shatter going from cold to hot and vice versa, as it expands and contracts and can’t handle the stress.
Without looking at one broken in person, it’s difficult to pinpoint the cause, if for instance it gets hit with something it is obvious as the glass ‘spider-webs’ from the point of impact… if it’s a constant pattern throughout it’s usually stress from expansion/contracting. |
behind the glass I see rust. maybe there was water and ice formed so the glass burst. but it's not my fault. maybe the glass was not properly glued at the factory
Defendit.. Member Since: 09 Aug 2020 Location: 's-Hertogenbosch Posts: 436 ![]() ![]() |
Very alarming, needs serious investigation. Could be a recall for all of us No Mud flaps for my 90.!
----------------------------------------- P300s MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3480 ![]() ![]() ![]() |
Could it be the result of accumulated condensation? If yes, think it is a design flaw. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2948 ![]() ![]() |
ls that rust, or is it adhesive of some sort?
that rust , and next third burst in Moskow , few day ago .
Nashvegas Member Since: 25 Dec 2021 Location: Portland, Oregon Posts: 40 ![]() ![]() |
This is a very odd failure pattern. Interested and following! Would love to see more pictures -- possible to take a few once that glass is removed?
It does look as if those rust-colored areas could perhaps be an adhesive in one image, but then there's a circular spot in the other photo above where it does look like rust. I wonder if the metal part that's rusting is manufactured attached to the window glass as a spacer, and that is what is rusting? If we had a photo of a new piece of this glass we might be able to determine. I haven't stuck a magnet on my tailgate / rear cargo door yet to see if it's steel or aluminum. |
This has to be a warranty fault? Mike
fourth case
this case was recognized as a guarantee. delivery time 4 week . ![]() Click image to enlarge |
01coccobet Member Since: 17 Jan 2010 Location: cervia Posts: 14 ![]() ![]() |
I am following this interesting topic.
Tks[/url] two gust is mei che one |
