Home > Faults & Fixes (L663) > Rear glass - burst
misha1976
Rear glass - burst
Rear glass - burst
the speed was 40 km per hour, there was no one on a flat track, I heard a pop. I stopped to look around - the glass burst all 4 corners and in the middle. Total car have 7000km. Call to the service land rover - they tell - not warranty . p.s after check few forum i see same story with burst glass in Moskow ( defender 90 -l663)
Post #940034 29th Jan 2022 3:17pm
Was the heated elements turned on?
Post #940057 29th Jan 2022 5:57pm
mse
I had this on my puma 90 I recall, they replaced under warranty…but many things different Mike
Post #940062 29th Jan 2022 6:20pm
misha1976
heated elements turned OFF
Post #940067 29th Jan 2022 6:33pm
misha1976
PHOTO same story with burst glass in Moskow ( defender 90 -l663) :
Post #940105 29th Jan 2022 10:42pm
Some toughened glass can shatter going from cold to hot and vice versa, as it expands and contracts and can’t handle the stress.
Without looking at one broken in person, it’s difficult to pinpoint the cause, if for instance it gets hit with something it is obvious as the glass ‘spider-webs’ from the point of impact… if it’s a constant pattern throughout it’s usually stress from expansion/contracting.
Post #940248 30th Jan 2022 6:41pm
misha1976
behind the glass I see rust. maybe there was water and ice formed so the glass burst. but it's not my fault. maybe the glass was not properly glued at the factory
Post #940289 31st Jan 2022 7:36am
Defendit..
Netherlands
Very alarming, needs serious investigation. Could be a recall for all of us No Mud flaps for my 90.!
P300s MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods..
Post #940295 31st Jan 2022 8:43am
Dinnu
Could it be the result of accumulated condensation? If yes, think it is a design flaw. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #940298 31st Jan 2022 9:01am
lightning
ls that rust, or is it adhesive of some sort?
Post #941192 5th Feb 2022 11:10pm
misha1976
that rust , and next third burst in Moskow , few day ago .
Post #941522 8th Feb 2022 6:45am
Nashvegas
United States
This is a very odd failure pattern. Interested and following! Would love to see more pictures -- possible to take a few once that glass is removed?
It does look as if those rust-colored areas could perhaps be an adhesive in one image, but then there's a circular spot in the other photo above where it does look like rust. I wonder if the metal part that's rusting is manufactured attached to the window glass as a spacer, and that is what is rusting? If we had a photo of a new piece of this glass we might be able to determine.
I haven't stuck a magnet on my tailgate / rear cargo door yet to see if it's steel or aluminum.
Post #942479 14th Feb 2022 4:12pm
mse
This has to be a warranty fault? Mike
Post #942531 15th Feb 2022 1:35am
misha1976
fourth case
fourth case
this case was recognized as a guarantee. delivery time 4 week .
Post #942891 17th Feb 2022 9:09pm
01coccobet
Italy
I am following this interesting topic.
Tks[/url] two gust is mei che one
Post #943874 26th Feb 2022 10:19am
