![]() | Home > Technical > Help! Loss of power, boost leak? 2.2 TDCI |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6638 ![]() ![]() ![]() |
Well found
![]() You should consider changing the boost hoses for silicone ones as you’ve got/will be getting them all off. ![]() ![]() |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3697 ![]() ![]() ![]() |
What Martin said! They will go and leave you in limp mode so you might as well get ahead of the curve.
Andy RV Member Since: 26 Apr 2014 Location: Somewhere Posts: 66 ![]() ![]() |
I used 40mm solvent weld water pipe from screwfix, the actually outside diameter is 42.5mm, this is perfect for the turbo end of the turbo to intercooler hose.
The passenger side hose from the intercooler is a slightly larger diameter, a female ‘40mm’ coupling should be about right for this at approx. 45 - 47mm. |
To close this one off, new intercooler fitted and we’re back in business! I would have liked a uprated version but funds are a little tight and I needed the 90 back on the road so went for the Bearmach ‘standard’ intercooler.
Here’s the original which had covered 78k miles. ![]() Click image to enlarge |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2135 ![]() ![]() |
Thanks gents, I think I will make one up, ready to find the inevitable leak on a hose or split intercooler. I really should get ahead of the game and replace the parts before they fail. The only trouble is following that principle I would rebuild the entire truck every 3 years given the longevity of most parts ![]() |
