Home > Technical > Help! Loss of power, boost leak? 2.2 TDCI
Page 2 of 2 <12
Martin
Site Admin
Well found Smile
You should consider changing the boost hoses for silicone ones as you’ve got/will be getting them all off.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #939288 24th Jan 2022 9:42pm
Co1
What Martin said! They will go and leave you in limp mode so you might as well get ahead of the curve.
Post #939332 25th Jan 2022 7:02am
piechipsandpeas
Australia 2013 Defender 110 Puma 2.2 SW Indus Silver
Ianh wrote:
What a great tool, simple , yet brilliant and cheap Bow down
What size pipe did you use ?
Hi Ian, it was 48mm outside diameter.
Post #939399 25th Jan 2022 1:01pm
Andy RV
I used 40mm solvent weld water pipe from screwfix, the actually outside diameter is 42.5mm, this is perfect for the turbo end of the turbo to intercooler hose.
The passenger side hose from the intercooler is a slightly larger diameter, a female ‘40mm’ coupling should be about right for this at approx. 45 - 47mm.
Post #939483 25th Jan 2022 7:06pm
Andy RV
To close this one off, new intercooler fitted and we’re back in business! I would have liked a uprated version but funds are a little tight and I needed the 90 back on the road so went for the Bearmach ‘standard’ intercooler.
Here’s the original which had covered 78k miles.
Post #940015 29th Jan 2022 2:03pm
Ianh
Thanks gents, I think I will make one up, ready to find the inevitable leak on a hose or split intercooler.
I really should get ahead of the game and replace the parts before they fail. The only trouble is following that principle I would rebuild the entire truck every 3 years given the longevity of most parts Very Happy
Post #940022 29th Jan 2022 3:06pm
Page 2 of 2 <12
