Home > Puma (Tdci) > Need help with my 07 defender 90 yet again! Thank you
Nick13
Ireland 2007 Defender 90 Puma 2.4 HT Zermatt Silver
4 month since my last dilemma and my last winging on this forum !! Not bad!!😂😂😂
First I'd like to thanks all for the help last time and yes the vcv was the culprit!!🤬
Now new story: starting got a bit weird in the last week with no but one light on the dashboard (battery) and no clicking or engine start !! It did start after 2 to 3 trial thou!! Today absolutely nothing is happening!! Same thing, no lights and no clicking or cranking!!
Battery is new
Starter motor 3 month old
New vcv
Cam
Maf
Injectors have been replaced
Etc,etc.
Fuses seem to be ok and switches are new
At this stage it seems to be a bit to much for my brain to understand!!! Hence my post!
Any tips ??
Thank you very much
Nick
Update!! Could this be the problem???
From the 10as box!!
Post #939408 25th Jan 2022 12:23pm
Balvaig
Cannot help with your starting problem, but I think that loose wire (orange?) is the aerial for the central locking/ key fob.
Hopefully more experienced help will be along soon.
Post #939420 25th Jan 2022 1:33pm
It's quite possibly the ignition switch on the end of the barrel. I swapped mine recently due to exactly the same symptoms and there have been a few other people with similar issues.
You can read about mine here: https://www.defender2.net/forum/post933318.html#933318 Darren
Post #939426 25th Jan 2022 2:09pm
Nick13
Thank you guys for the replies! Landroveranorak , the connections at the back of the switch looks fine thou!?? If the barrel was faulty would the battery light stay on??
Post #939439 25th Jan 2022 3:04pm
It depends on the nature of the failure, I guess. I think the battery light would stay on as it only goes off when current is drawn by the starter motor, which isn't happening if the switch isn't working. Darren
Post #939443 25th Jan 2022 3:14pm
Martin
Site Admin
If nothing except the battery light is on (and your coolant gauge at max hot), then your ECU is off, or the CAN bus is broken.
The above is the default the cluster shows when it has no CAN messages arriving.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #939488 25th Jan 2022 6:13pm
Martin
Site Admin
Loose wire is alarm aerial - nothing to be concerned about.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #939490 25th Jan 2022 6:14pm
